gb2098
can actually answer some of the OP's questions but currently at work so only going to tackle one.
sadly the Victorian age got around to deciding that bare stone and exposed wood was the more appealing look, and scrubbed off all the limewash from the surviving castles to get that effect. (they also tended to tear down large parts of castles to build all new versions with less defensive minded styles)
there has been some push to re-limewash surviving castles to their original looks, particularly those being used as historical tourist spots, but there has been a lot of people who don't like that idea.
for example:
http://www.slate.com/blogs/the_eye/...great_hall_illustrates_the_complexity_of.html
Stirling castle.. on the right a hall restored to its original limewashed state (circa records from the 1600's), on the left the bare stone the victorians rendered it into. (which probably wasn't originally quite so dirty)
of course, for most castles it is likely that they only limewashed every couple of years (that would get expensive if the castle wasn't near a ready supply of the materials.. and it would be very manpower intensive to scrape the outer layers off and reapply it) , and would get patchy and stained from the weather (and sieges, if they happen). though any castle the king is in or will be visiting would certainly get a nice fresh coat frequently.
the TL/DR version: medieval castles tended to look rather more like the "fantasy land" versions seen in kids toys and theme parks, with smooth whitish walls and decorative color trim, but later generations disliked that look and turned them into grim edifices of bare stone.
generally no. while surviving sources are a little vague on the issue (since most people never bothered to mention things in common practice) and there are few surviving examples that didn't get screwed up by later generations deciding they liked some other aesthetic look and renovated or just abandoned and left to weather, all indications are that medieval castles generally had rather thick coatings of limewash applied to them, partly as a protective feature (reduce weathering, etc) and partly because a (relatively) clean smooth surface was seen as aesthetically appealing at the time. the main colors tended to be white (usually more of a very pale light grey or offwhite) or even a light yellow, depending on the source of the lime and chalk used for the limewash. (there is also evidence that with some castles in the later medieval periods, the owners imported specific varieties of limestone and chalk to get specific colors.) the limewash could also be colored using additives like ochre, and it appears some castles used such colored limewash to decorate parts of the castle for aesthetic effect. the limewash also helped protect the exposed wooden parts of the castle from water and fire, as well as disguise the fact that some bits of the interior were made of wood rather than stone. (it also helped hide damage from sieges and such.. including areas where the walls might be weak due to old damage or shoddy repair)- were medieval castles bare stone?
for example:
