AoS Ironman Challenge.
OldBlood
LizardWizard
Grand Skink Handler
4,286
9,466
Play this list till you win three games:
Allegiance: Seraphon
LEADERS:
Skink Starseer
(200)
- General
- Artefact : Incandescent Rectrices
UNITS:
12 x Skink Handlers (160)
3 x Skink Handlers (40)
5 x Saurus Knights (90)
- Lances
- Lances
- Lances
TOTAL: 990/1000
EXTRA COMMAND POINTS: 0
WOUNDS: 74
Hey man skink handlers eye gouging is no joke ive had my 3 skink handlers throw out a few damage on multiple occasions lol
I’ve had an awesome moment in one of my games where a single handler went toe to toe with a Khorgaroth for 3 rounds and ended up killing it with a jab to the eye!
Leaders
Skink Starseer (200)***
- General
Battleline
- Blades
- Blades
- Blades
10 x Skinks (60)
- Boltspitters & Moonstone Clubs
10 x Skinks (60)
20 x Skinks (120)
20 x Skinks (120)
Units
9 x Skink Handlers (120)
1 x Salamanders (40)
Total: 990 / 1000
Extra Command Points: 0
Allies: 0 / 200
Wounds: 107
That was as close as I could get.
***If I proxied something for the SSM.
To be honest, I wouldn't be surprised if this list would perform suprisingly well as long as your opponent doesn't have loads of shooting. You got plenty of sacrificial fodder to absorb unfavorable charges and withle an enemy down and handlers are surprisingly reliable. And Knights, although underwhelming, can hold the line and if you get so Lucky as to get a decent charge or two you might even catch an opponent completly un aware and steamroll in.
However, the moment your opponent has significant ranged firepower, or some particular strong units you'l probably get destroyed.
I would make one change to the list though. Divide all the handlers up into minimum size units. Maximize the amount of wasted attacks due to overkill and available fodder units for speedbumps.
The goal was not to make a good list:D Skink Handlers are better in MinSU.
LEADERS:
Skink Starseer
(200)
- General
UNITS:
- Lances
- Lances
- Lances
TOTAL: 990/1000
WOUNDS: 74
i have achieved one win thru grit guile and mule headed stubbornness im going to go lie down now and never do this again.
was playing treasure hunt against gloomspire gits Dankhold Troggboss,Fungoid Cave-Shaman, 6 rockguts, 20 shootas , and fanatics longways board. he wins drop spends first turn calming two objectives rolls empty holes. my turn handlers LoSaT to middle objective rune the rest down feild marching my knights i sit my starseer on the closest objective and end turn i roll and get a 6 for the objective farthest from his lines i hold the treasure. roll for turn order he gets 3 i get 5 i go again i fail LoSaT i run the middle ground handlers as close as i can and set them up in a line. same with the other handlers setting up in lines 4" from each other using turaine to block after that it was just staling tactics until turn 5. i ended up with 7 knights and my starseer.
You are leading the pack. Well played!
