Nun-pak
Warscroll
Should the save be +5 or +6 , To Hit and wound be 5+ 4+ or 5+ 5+, Alpha?I'd say make it permanent on whatever they attack, succesfull or not the projectiles will presumably land vaguely near the target and break so it'l be annoying regardless of it being a proper hit or not.
In exchange, remove the rend of the projectile. Also lower their stats so they don't just outperform skinks, or make em significantly more expensive than normal skinks.
Also add in wary fighter.
This way they're a pure supporting troop that will do little damage, but can be a giant nuisance by constantly dropping -1 to hit on important targets that is very good at running away from any threat. It makes em perfect for goading an enemy into going after them.
