I watched a Batrap last night and he rolled a D6 for LoSaT and after a pop up said "Roll a D3 now" but I can't find any rule errata to confirm this.
So is LoSaT a D3 roll now?
Cheers
Crow
That's a negative, sir!
It is still a D6, but 1-2, 3-4,and 5-6 are the results.
I hear you asking: "Why @Aginor, isn't that the same?"
Now... it isn't the same. Not completely. You will see the difference if you start applying modifiers like Curse of Fates to it.
Example making clear what the difference is:
Old rule: You roll a 1. You use Curse of Fates to make that a 2. All is good.
New rule: You roll a 1. You use Curse of Fates to make that a 2. All is NOT good.
If it was a d3 (which it isn't): You roll a 1or2. You use Curse of Fates to make that a 3-4 (on a d3). All is good.
Indeed, the "extreme" results basically became more likely.if you compare the new table to the old one, the positive thing is that with Curse of Fate now only the 1 is negative, while 4-5-6 are very good results.
we "pay" with a 1/6 chance to be blocked, the 50% chance of being able to teleport, move and charge. Which is huge for oldblood on carno, stegadon, dread saurian...
I would say yes, I don't know any rule that would restrict that.Can LoSaT be used twice on the same unit in the same turn in case the first teleport fails?
