Nice to see more people playing KoW!
In fact as
@Killer Angel said Salamanders and Ghekkotah play a very different role. For starters Salamander Primes (the basic troop of the Salamanders, they are the equivalent of the regular Saurus) are one of the best infantry in the game, and is one that is designed to be played in horde size, let me explain why:
- Their attack progression is Troop/Reg/Horde - 10/12/25 so imho fielding a Regiment is not worth it, just two attacks more than a troop, better field other kind of regiments (Ancients come to mind quickly)
- They only hit on +4 so to hurt the enemy fast you need a lot of attacks, Ancients hit on +3 so their 12 attacks are much more efficient and they can't be
wavered.
- The best worst thing about hordes are their footprint, they are so huge that is really difficult to maneuver and most importantly charge without being
hindered, that happens when you charge through difficult terrain of obstacles, rendering the charger -1 to hit. Salamander Primes have a rule called Pathfinders, they ignore difficult terrain to all intents and purposes. That is a HUGE advantage in KoW, specially for a unit the size of a Salamander Horde. They can March through difficult terrain, and best of all charge through it. This last thing is important for defensive purposes, salamanders are not fast so I would use them as a huge anvil, they perform as tar pits extremely well, just position them in a way that if the enemy wants to charge you they have to move through difficult terrain, or place them in the edge of a forest or any dificult terrain but leave some of the terrain in front, when the enemy charges you they will be hindered and won't do much damage and then you can countercharge in your turn an start grinding, with the advantage of not being hindered, which is a huge advantage.
Of course this tactics works best for scenarios like Dominate or Pillage, but if you position your troops well you can make it work every single time. An even if the enemy chooses to avoid it and charge something in the sides of the Primes, you can then charge their flank and deal 50 attacks. Remember that KoW is all about planning and tactics.
Ghekkotah warriors are a very controversial unit for me, they don't seem very good, they are not pathfinders, they hit on +5 which is rubbish to be honest and their deffense is pathetic. Good thing is they are cheap, not cheap as goblin rabble which should be the equivalent in combat strength and that bothers me. Let me explain:
Goblin Rabble horde has this stats:
Unit Size Sp Me Ra De At Ne Pts
Horde(40) 5 5+ - 4+ 25 19/21 125
Ghekkotahs for 40 points more have:
- 1 more Speed
- 1 LESS Defence
- Same Nerve
- Vicious (They re-roll the natural 1s to wound)
- They are not Yellow-Bellied (When they charge they have to roll a die and if they roll 1 they cannot charge)
- +5 Attacks
They are not bad by any means but I think there are better options to spend 165 points, combat wise. The thing is in KoW to be able to field Monsters (and trust me with Salamanders you want them) and heroes yo need to unlock them, works like this:
HORDE Unlocks:
- 1 Hero
- 1 Monster
- 1 Warmachine
- 4 Troops or irregular units
REGIMENT Unlocks:
- 1 Hero OR 1 Monster OR 1 Warmachine
- 2 Troops or irregular units
So what Ghekkotah are really good at is unlocking the juicy options for a lot less that using Salamanders. I play a thematic Ghekkotah army so I use Ghekkotah Hordes to unlock a lot of options for a small amount of points, and a unit with 19/21 Nerve and 30 attacks can be used to hold a unit for a couple of turns or kill some small units, I use them in combination with Hordes of Tyrants (Kroxigors) and they are amazing to hold big hordes on the front and flank with the tyrants or viceversa.
But Ghekkotah warriors shine when fielded in Regiments, they cost just 100 points, deliver 20 attacks and are quite expendable. Use them to flank units that are being hold by your anvils and watch the enemy stop laughing at them when they do 40 attacks or to capture objectives or hunt units or clear out chaff.
Hope it helps!
