Lord-Marcus
Sixth Spawning
Keep going!But vile Chaos sorcery that got me to paint... now that is POWER!
Unfortunately I started playing Skyrim.... realistically there will be no painting for the foreseeable future.Keep going!
And I've started playing return of reckoning. I'm going to jump between that and paintingUnfortunately I started playing Skyrim.... realistically there will be no painting for the foreseeable future.![]()
Thank you!Sweet! They look great!
I don't paint models often so I figured they might as well move around in style.And with movement tray to boot!
Thank you my friend!coolio. they look good.
Thank you kindly. They took me a very long time to finish... but I am happy with the results.You should paint more... Those minis look great!!
I painted Dwarfs!!!Loving those Chaos Dwarfs! Any thoughts of doing a whole army in the same scheme?
Thanks @Crowsfoot . The cannon is mostly done. I just need to complete the furnace doors at the back, the chains that tie it to the ground and the skulll piles (soooo many skulls). After that I have some assembly work to put on the doors, wheels and chains. Lastly, I need to complete its base. I'm a little bit worried as to how I will securely anchor the (metal) hellcannon to its base.Your on a roll this year, keep at it that crew looks really good is the cannon done yet?
That was my thinking as well (pinning and 2 part epoxy). The only problem is that it will have to be a pretty shallow pin into the wheels because of the hollowed out section.Drill and pin the under side of the wheels or use 2 pack epoxy glue
What sorcery is this? Hellcannon crew... done & done! (the bases will get their final drybrush highlight once the cannon is based so I can match them up perfectly)
View attachment 44927 View attachment 44930 View attachment 44928 View attachment 44929
Thanks @Warden ! Hopefully the Cannon will be done (somewhat) soon!Nice looking evil dwarfs... bring on the CANNON!!!!![]()
