Every time i use a unit of 30 saurus against my friends khorne army the saurus, melt away emidiatley because of bloodboil or bloodwarriors. Its not like they dont have support i keep having skinks shoot at them and spells like mistic shield cast on them but that doesnt change anything. I dont know how to counter them
Enemy army comp 20 blood warriors 6 skull crushers and slaughter priest with hackbane
You really need to abuse teleporting and movement increases with the Saurus so they can get reliable charges and fight first. They can do an absurd amount of damage in units of 40 with re-rolls to hit. The new rules will let you keep the Slann as the general and use a foot oldblood command ability to get 3" closer after the teleport. That said, you generally want more than one big unit of saurus if you're taking any at all. A single unit of 40 can do some damage, but once it dies, you need something to follow it up. Units of less than 40 aren't really worth taking unless it's a unit of 10 to fill out a Sunclaw/Bloodclaw.
I usually bring a Vast intellect Slann and cast curse of fates + summon starlight on the saurus, then try to teleport, and if it's a 5+ (curse of fates lets the 5 turn into a 6), I teleport forward and wrap around the target unit(s), leaving a daisy-chain to keep them in range of an astrolith. Usually, whatever they hit suffers critical damage and can't do too much damage back. Rinse and repeat with a second unit of 40. After the new rules, I'd bring an oldblood and always teleport, then reform 3" closer, though the unit will be able to move on a 4+ with curse of fates.
Clubs vs Spears was looked at in another thread recently; Clubs can still fight in 2 ranks, as long as you have your models honeycombed, with their own and enemy models. Spears are only beneficial if you are getting at least 1/3 more models into combat, which, if you are maximizing models within 1", isn't always easy to do, as the 3rd rank is never within 2" of the enemy, but the 2nd rank will be within 1" with maximized contact. Spears will be more reliable for getting in the extra attacks though, so might be better just for that.
A 1k saurus alpha strike list would look something like this:
Allegiance: Seraphon
Saurus Oldblood (120)
- General - Might War Leader
Skink Starpriest (80)
- Incandescent Rectrices (or you can cut this and the Razordons for an Astrolith for re-rolls to hit.)
40 x Saurus Warriors (360)
2 x Razordons (80), 10 skinks, or a skink priest
Total: 1000
Wounds: 97
At 750 (that Khorne list is 780, unless there's more to it, so I assume that's what you're playing at), you can get something like this if you want to bring Saurus:
- Clubs
10 x Skinks (60)
4 x Razordons (160)
Total: 780
Wounds: 73
I don't think the 780 list is particularly good, but It's pretty hard to make a good ~750 list with Seraphon, and it might do alright, though a carnosaur, a starpriest, and 80 skinks, or 40 skinks and 10 knights would probably be better.
