Lord-Marcus
Sixth Spawning
I'm assuming he meant "doesn't"how do chariots work nicely in a jungle? Wheels and jungle tend to not cooperate well
Chariot does play nice in Jungle.
they still mostly live there though, not like they have any major civilizations outside of it.Well, they don't only fight in jungles do they?
But yeah, fair point.
Right then... Lizardman-constructed wheeled anything is unlikely. Except maybe:
Temple Guard Chariots
Only found in temple cities where they can operate on the paved plazas, roads, and causeways. Could only be deployed in an army defending a temple city and confined to paved areas.
Chariot category equivalents might include:
A) Two cold ones, harnessed as a team. On their backs is a shared Howdah. Upon or Inside that there is a team of (4?) Skink Archers. (I think I have suggested this before.) (50x50 Base footprint, or oval AoS equivalent.)
B) Two Cold Ones towing a bamboo constructed platform which floats . Same magic as a Slann Palaquin ...except... this is the Skink Priest version: less power, less weight, less payload. It needs Cold Ones for propulsion; it is mostly bamboo not stone; it carries a few Skinks (BOWSKINKS!) as crew and shooters.
C) Four Cold Ones lashed together in a team like bearers. There is a 75x50mm platform centered atop them (the whole business is based on a 50x100 chariot base.) The platform carries a massive Bolt Thrower designed to hurl Glyph Bolts, an explosive hollowed out log based projectile. A mad Slann’s answer to those Ogre Chariot Artillery things.
B seems like a cool idea, though cold-ones might be a tad aggresive for this purpose given that they like biting and such. A calmer mount is probably prefered so the platform doesn't get launched all over the place. Dragging it by say salamanders could already work better. Or just make up some new animal to pull it.
Cold Ones don’t seem much worse (for viciousness) than the fierce boars pulling Orc and Beastmen chariots.B seems like a cool idea, though cold-ones might be a tad aggresive for this purpose given that they like biting and such. A calmer mount is probably prefered so the platform doesn't get launched all over the place. Dragging it by say salamanders could already work better. Or just make up some new animal to pull it.
Trog's also have the issue of being the same shape as cold ones. I'd guess trog's carnosaurs & cold ones are not very fit for carrying howdahs.Imagine you have a placard in your hand and chant the following while rasing it up and down.
Baby trog! Baby trog! Baby trog! Baby trog!
Those boars are much broader and stable and generally don't try to leap on top of an enemy and bite it's juggalar out. Makes em a lot more fit for pulling a chariot than cold onesCold Ones don’t seem much worse (for viciousness) than the fierce boars pulling Orc and Beastmen chariots.
But yeah, just make up a third or fourth species of Cold One. I can think of three plastic types plus the old metal Horned Ones from that Old DoW box. Spiked Ones perhaps.
I was thinking that basic type of lizard because it would be possible to convert some (if one had spare Lizards).
Razordons is a thought.
We are imagining very different creatures somehow.
Boars fit a 24x50
H Ones fit a 24x50
C Ones fit a 24x50**
And it is ^ possible to ride them all. If they can be ridden, they can be harnessed to a chariot, or they can be stuffed under a howdah.
If they fit the same base they are equally broad and stable.
**Three different styles (species?) in plastic.
Boars fit a 24x50
H Ones fit a 24x50
I'm not saying they're not big enough for it. I'm saying that putting a howdah on something like a cold one (or a carnosaur, or a troglodon) wouldn't be comfortable for the people in the howdah. Idem for a war-chariot.
Cold one's are bipedal predators who's main weapon is their bite. They will naturally try to lunge for their enemies and bite at their soft bits. If you put a howdah on that you'l fall off. This makes em unfit for this.
For a chariot they could potentially work, at least if all you care about is that they pull it. Having them actually charge into an enemy while pulling a chariot is probably not that great an idea. They're not good at crashing into enemis. Boars on the other hand who are used at chargin at someone with their tusks are much more capable of withstanding a charge like that.
I don't think that'd be particularly effective.![]()
Anything is possible... just add lasers!
I mean come on, the people on the flying mounts are bigger than their mounts, that ain't gonne work well.
In a world ruled by magic and imagination anything is possible.I mean come on, the people on the flying mounts are bigger than their mounts, that ain't gonne work well.
Once upon a time there was this Crocodile that had long tall legs so it could run on land. RUN..!I'd like to see temple guard cavalry equivalents...
Did real-world horse drawn chariots ever do that? Kinda thinkin’ that was not how they were used.Having them actually charge into an enemy while pulling a chariot is probably not that great an idea.
