Looking pretty is half the battle
Not seeing that one
That is due to your magical phone again.Not seeing that one
*Mummy scream*That is due to your magical phone again.
That one works.
Good article on the priesthood
https://www.ancient.eu/article/1026/clergy-priests--priestesses-in-ancient-egypt/
You aie, do the same yourself. Look above, and in the just for laughs threadThere it is again... quadruple post, minutes apart. The post boosting has become blatant and obvious.
@Killer Angel : that's why he is to catch you on the notable members list. The NIGHTBRINGER disapproves. There is no "glory" in it.
Make that a quintuple post...
You are incorrect good sir. The just for laughs posts are released over time. I VERY SELDOM repeat post seconds apart. There is a big difference. No one is expecting you to edit a post hours later, but at least you shouldn't artificially split them to get greater numbers.You aie, do the same yourself. Look above, and in the just for laughs thread
I do take into consideration time.You are incorrect good sir. The just for laughs posts are released over time. I VERY SELDOM repeat post seconds apart. There is a big difference. No one is expecting you to edit a post hours later, but at least you shouldn't artificially split them to get greater numbers.
Time and intent is the difference.
But only in the last week or so. I've never noticed it before. Your pattern of posting has shifted 180 degrees in the last 2 weeks. Right after declaring your desire to reach Slannhood, you changed your posting style. Say what you will, but patterns are easy to spot my friend.My free time at work comes in waves, and I post as such
