Warden
Tenth Spawning
Enough work has been done on at least one of the thrones to give you an idea of what they might look like, closer to being finished:
More with better lighting are required, but you can see the details on the little foam-base pieces now (the original is in the background, I will do more scale shots later).
I originally tried adding vines with clay but that was a fail, so I switched to the metal wire bend in various curves to stand in for the vines on the palanquin instead. The next experiment will be with tiny leaves, not sure if they will be plastic jungle-plants or something else yet.
I also was going to use hobby-shop jungle plants on the base for the slann's "cushions" but they didn't look right, not sure what I will do for those yet.
All in all pleased with the progress so far, but it is really slow!
