Hi i have just started collecting my seraphon army and was looking in to Thunderquake Starthost.
I have some problem understanding the warscroll.
“The Creator’s Will: The Engine of the Gods or Troglodon, and any units from the
Thunderquake Starhost within 8", are guided by the will of their creator. At the start
of each combat phase you can declare that all of those units will either be swift, in
which case you can re-roll charge rolls and failed hit rolls for them, or savage, in
which case you can re-roll failed wound rolls and save rolls for them.”
A: For the first does it mean that all units need to be within 8” of Troglodon of Engine to get the buff?
B: it says you choose at the start of EACH combat phase. So twice a round, in your turn and your opponent's turn. Otherwise it would say "in each of your combat phases" like other warscrolls do.
C: it does NOT say something like "until your next hero phase" or "in the following combat phase" which would indicate when the buffs end. So it is either
C1: the buffs apply only in the combat phase
or
C2: the buffs apply until the next combat phase
or
C3: they end at some other, arbitrary point? I'll ignore that one for now.
D: it DOES mention a CHARGE roll, which can never occur inside a combat phase.
--> So if C1 is true the charge buff NEVER works.
--> If C2 is true the charge buff works, but never in the first round (you choose it after the charge phase), it applies in your NEXT turn, which is weird.
--> If C2 is true it even means that I can use three of the four buffs in one turn (I choose swift the turn before so it applies in my next charge phase, then in the combat phase I choose savage and get the other two). That sounds needlessly complex to me so I assume it could be an error.
--> C2 also automatically would mean that all the buffs on saves, wounds, and hits apply all the time, also in the shooting phase or when a special ability allows them to attack or be attacked in some other phase
or
or
