So, i was thinking about some shenanigans on battle field and came up with this (un)playable warscroll:
Leaders:
Slann (general) + Great Remember + Rectrices/Prism
Engine of the Gods
Scar-vet on carno + blade of realities on warspear or Skink Starseer and 40 points goes for another sally/razor
Units:
40x skinks with bolt
20x skinks with jav
20x skinks with jav
3 handlers + 2 sallies/razors
Behemoths:
Bastilladon with arc of sotek
Stegadon
Battalions:
Thunderquake starhost
1970 points
Whole thing doesn't work, cause you port on 9', but range is 8'. Bad and sad =(
Still, what is the plan?
Horde - port stegadon and SUNFIRE. Season it with CRASHING STOMP and enjoy yourself.
Anything fat? SNAKES (tbh too unreliable, but it is still fun) AND SALLIES!
Need to tie something? SKINKS!
I'm not sure if you can port your units out of combat. If you can it is EVEN MORE FUN!
If you want to be cool you have CARNOSAUR!
For biggest effect you need to place basti as good as possible and try to get at least 4 in range (with diametr of ~40 cm it is not that hard considering that it is 1/3 of table width). If it is 6 - even better! It is 100% 12 mortal wounds. 4 units in range on average will give you 8 mortal wounds (nothing to sneeze at). But, against hordes, it is too bad (as bastilladon in general). The thing is - you can use it as area denial and battlefield control. Either it will be piled on to be killed fast or ran from to not get those nasty hits. It can help you to position Carno+Stegadon on your next turn so you will be able to destroy something fast. But it is just theory...
Will try this list on saturday. Can you giva any advice? Except for "Don't play it lol".
Leaders:
Engine of the Gods
Units:
20x skinks with jav
20x skinks with jav
Behemoths:
Stegadon
Battalions:
1970 points
