Nielspeterdejong
Does anyone have a link to a video where I can see the Seraphon vs Sylvaneth match? I'm dying to watch it
I think the only way to watch it right now is to be a Twitch sub and go rewatch the Stream :/ Would love if someone had another way to watch it tough, I'm dying tooDoes anyone have a link to a video where I can see the Seraphon vs Sylvaneth match? I'm dying to watch it![]()
https://www.twitch.tv/videos/168718266Does anyone have a link to a video where I can see the Seraphon vs Sylvaneth match? I'm dying to watch it![]()
The post in the other thread by @LordRibbit confirmed everything here but the point costs.
With regards to the ressurect, I hope you simply roll the dice after taking all the wounds, and regardless of the damage return with D3 health on a 3+?Artifacts 2, 5 and 6 looks nice. 1 Seems like rubbish. 4 and 5 are also useful.
How do you guys read Incandescent Rectrices? If you take more wounds than you have are they all lost and you heal back D3 on 3+? Or say you take 3+ more wounds than you have then you have no chance of coming back at all?
They really want us to include Slann in ALL of our army lists. They seem so great that there is no reason not to. Same with Skinks in blocks of 40, why wouldn't you run them for 200?
Damn their marketing strategy. My 54 skinks now need new friends.
This is how I interpret it, otherwise its gonna be pointless. You rarely die on the last attack its usually overkill.With regards to the ressurect, I hope you simply roll the dice after taking all the wounds, and regardless of the damage return with D3 health on a 3+?
1: meh. Too random for me.
3: It doesn't say mount weapons are illegal (like other weapon artefacts do)!! So say hi to the Carnosaur with -2 rend on his Jaws attack!
5: good for a melee hero like an Eternity Warden or an Oldblood. Does sound like it isn't one use
6: this is not just once is it? Sounds like every turn. Not bad. You could give it to an Astrolith Bearer, teleport him somewhere you need him. Since he doesn't move anyway that's the perfect item for him. if you want to move him just teleport him.
Yes, it is a stretch, but the texts for ALL other melee weapons artefacts explicitly say "it cannot be a weapon used by a mount if they have one", this one doesn't.It's a weapon that the bearer can use. It's a stretch to apply it to the jaws of the hero's mount, even if it's the same warscroll.
I think any support unit that doesn't have to move in that turn can make good use of it. For example a Starpriest/Priest or a Skink Chief standing behind his battleline buffing them without the need to move, or an Eternity Warden standing amidst his guards already locked in melee. Note that the enemy unit doesn't even have to be visible! No line of sight needed so you can cast this from behind a bubble wrap.That's probably the only real good use of this item, that otherwise would be almost garbage
I pretty sure they said on the live stream that in the new GHB artifacts can't be used my mounts unless it says so. GHB1 was the other way around.3: It doesn't say mount weapons are illegal (like other weapon artefacts do)!! So say hi to the Carnosaur with -2 rend on his Jaws attack!
BOOOO!!!! That makes the artefact basically one of the Order ones, just by another name.I pretty sure they said on the live stream that in the new GHB artifacts can't be used my mounts unless it says so. GHB1 was the other way around.
It says "if the general is a SKINK" in the keyword font, so it implies to me that a basti can take these abilities, but I don't think it'd be able to do number 2 because the skinks use the bastiladon as a mount, which I assume is where it gets the SKINK keyword from... Interesting though, hadn't thought of that!I apologize if it's been asked before, but can you make a Bastilladon your General and give them the skink command abilities. Because number 1 and 2 look insane on a Bastilladon.
The GHB2017 says your general must be a HERO. You can no longer choose a unit captain or bastiladon as your general.It says "if the general is a SKINK" in the keyword font, so it implies to me that a basti can take these abilities, but I don't think it'd be able to do number 2 because the skinks use the bastiladon as a mount, which I assume is where it gets the SKINK keyword from... Interesting though, hadn't thought of that!
