Hi,Hello u got a question about bastiladons light heaven does it need casting value becaus3 i read somewhere is magical and it needs casting value?Also does lord kroak can cast 4 spells on the Hero phase?
Wow ty that means he is very strong modelHi,
- For the bastiladon's light heaven, is just an ability on his Searing Beam. When you use the searing beam, if you target a unit of Chaos Daemons, the damage characteristic will be 3 rather than 2.
- For lord Kroak, he can indeed cast 4 spells during the hero phase.
Wow ty that means he is very strong model![]()
Keep in mind though that in matched play those have to be four different spells which makes him considerably weaker.
So wait a minute... match play is the "build an army based on points" system. It's my understanding that is when Lord Kroak does use his Celestial Deliverance as written in the book. And tbh, he should have a reduced point cost when he cannot be played as written. That is an imposed handicap and should be adjusted accordingly. There are only two spells in the game: Arcane Bolt and Mystic Shield that are universal. Then he gets his Celestial Deliverance, then what? There is an unused spell.
In Matched play you can use his Celestial Deliverance spell up to three times.Keep in mind though that in matched play those have to be four different spells which makes him considerably weaker.
