Blog Marcus' other projects
What compound do you use in conjunction with your rolling pins to make your bases?
I use super sculpey. It's relatively expensive unless you have a supplier like I do.
Hard, not brittle, little bit of flexibility
Thank you!
I found several different kinds of Super Sculpey. Do you use the original, or some specialty kind?
Definitely burnt iron for the ultramarines.
