I made my Fire elementals from silicone paste. It is quite easy to shape into something that looks like flames.
Here is the result:
I am in the process of making a Greater fire elemental as well. Will post pictures when it is done.
As you might know I use my Slann as a GFE, and 3 Salamanders with handlers as a Horde of Fire Elementals, I have another Horde in Wipe too but I will finish my Tyrants first.
Very nice and inexpensive I bet?
have you a link to this paste?
It cost me 30 SEK, which is around 3 euros, and was enough for two horde of Fire elementals. Quite cheap for 400 points worth of troops.
I bought it from a hardware store here in Sweden called Biltema.
http://www.biltema.se/sv/Bygg/Kemikalier/Silikon/Silikon-transparent-2000017158/
Any hardware or similar store that carries chemicals and/or construction supplies would be my first bet.
Reaper makes a clear Orange-Red fire elemental. Item number 77082.
Here are some pictures of mine:
Top image is the ^ raw unfiltered ^ picture.
There are filter gizmos in the camera and I started playing with them. Three of the results are below:![]()
That guy is ~2.5 times as tall as a Saurus Warrior. I will try to shoot a new pic with a size comparison for you.They look good, what size are they compared to say a saurus warrior?
You can see a comparison to that model in the images of my whole army on the Salamander Paint Schemes thread. It fits a 50mm x 50mm base comfortably. Not sure whether it would fit a 40mm.
Do you use it as a Greater fire elemental?
Indeed, with Reaper Medium Fire Elementals as FEs.
