Hey guys I found this awesome link to experiment with colors. I found it very useful for testing the color schemes you have in mind and make a decision
I'm sure there are several other ways to use it in a more clever way, but this is how I am going to use it:
first of all set the language to English in case the webpage uses another one (at the bottom right).
Now.
1st method - Complementary
Let's say you wanna come up with a new color scheme for your Saurus: you want for them 2 main colours and a lot of contrast among them to make them really visible... And let's also say you want a "Lime" tint as one of the two colours.
What should you do?
- Set the Rule Color to "Complementary"
- Click on the 2nd square, then again on the small triangle in it to set this as the Base Colour.
- Move the relative circle (which now has a little white border) on the Color Wheel and put it between green and yellow to choose the "lime tint".
It is better to move it as far as possible from the centre of the wheel.
- You can see 4 coloured bars under the square representing the color you are choosing: focus on the 4th bar, and be sure the slider is at 2/3 of the lenght. You can also copy and paste 99B500 in the "HEX" field to get the exact same color I choose. RESULT: Now you can see in the first 3 squares three "lime tints", a darker one, a base one and a lighter one.
These are the colors you will use to paint your Saurus skin in order to get the lime colour you wanted (the darker tone is for the recess, the lighter one for the details/higlights/drybrushed parts).
And remember you wanted another super contrastant colours, maybe for the back of your Saurus? You have it in the last 2 squares!
2nd method - Shades
Let's say you wanna paint a part of your model Blue, and you don't know which color to use to make the different layers you will need to create shadows and highlights.
What would I do?
- Set the Rule Color to "Shades"
- Select the 3rd square and make it your Base Color. Put the slider of its 4th coloured bar at 50% of its lenght and then move the relative circle on the blue you like most (example: HEX=006585).
- Select the 1st square, NOT setting it as Base color, and put the slider on its 4th coloured bar at 20% circa of the lenght.
- Do the same for the 2nd square, putting the slider at 40% circa.
- Do the same for the 4th square, putting the slider at 75% circa.
- Do the same for the 5th square, putting the slider at 100% circa. RESULT: Now you know the colours you have to use/buy to create the layers of blue paint on your miniature!
I hope everything is clear, but being English not my first language it might be a little confusing...
Ask me if you have doubt and at least I'll try to answer your questions!
I think @Freddy25 really did a great job explaining it! But in case you still need a little more info here is a quick guide that I found to be really straight forward and useful as it summarizes theory of color really well in my opinion:
