Chameleon Skink
dwarfepic
So this was my fourth or fifth game and his sixth or seventh. also, my army was considerably outnumbered, but this did play to my advantage...
Anyway, here are the lists:
Khorne:
20 blood reavers
20 blood reavers
10 blood warriors
2 khorgoraths
1 bloodsecrator
1 bloodstoker
1 mighty lord of khorne
Seraphon:
15 temple guard
10 chameleon skinks
lord kroak
asrolith bearer
bastilidon
set up: my army was smaller so I put the majority of it in one corner so that my opponent could not get all of his models attacking at once. he had his force spread across the battle field and would do a serious amount of maneuvering to get everything at me. my skinks set up in hiding.
turn one:
I went first and the turn followed through like this. lord kroak used his ability to get two insights and the used one of them casting comets call, inflicting three wounds on the bloodsecrator. he then give mystic shield to the temple guard and rolls poorly on celestial deliverance( out of range). next the skinks pop up and shoot at the bloodsecrator, killing him before that portal of skulls can be opened. turn one objective complete! bastilidon only roll two shots so I use an insight, making it four. three shots miss and the only hit fails to wound. still that things gonna stay around for a while so it will get lots more chances to kill. end my turn one. on his turn my opponent uses lord of khornes hero thing, and whips one unit of blood reavers with the bloodstoker. he then moves at my skinks, charges and kills all of them! my rolling was poor. end of turn
turn two: I win the roll of and so use kroaks ability to get two insights and then cast comets call nocking of two wounds from the lord. next is a failed mystic shield, then celestial deliverance killing one reaver. a second celestial deliverance kills two more reavers. then I kill two blood warriors with the basi. I then begin to plan for next turn. my opponent ,on his turn, uses all his ability's and runs straight at my army. the temple guard roar at them and do not flinch. end of turn
turn three: again, I win this roll of and take initiative. I start by gaining a single insight from kroak , which is then used in casting celestial deliverance. wow, does that spell hurt. three wonds on lord of khorne, one dead blood warrior, three dead reavers, two wounds on a khorgorath. ouch. then a second casting of it kills another blood warrior, one more reaver and drops the lord of khorne down to his last wound, which is then knocked off by a comets call. ouch. mystic shield on temple guard. skinks the pop up and kill another blood warrior, then yet another three are killed by the bastilidon. very few of the blood gods chosen remain... on the turn of khorne I get a little worried by the vast number of models charging at me. he does not do his khorne lord ability... the lord is dead, and he whips the reavers and the khorgoraths. them he moves in my direction, does not shoot( he is khorne though) and then charges. after this things got complicated... in short the blood warriors went, as the temple guard ripped them apart, and I put the rest of my attacks on the khorgorath.he then kills two guard, and my basi kills a khorgorath. then the rest of his hits nock of two of lord kroak( who ends up fine) and kill another guard. the line holds. end of turn
turn four: he finally goes first and it hurts. a lot. he whips the khorgoraths and then does nothing with their ranged attack. then in combat a unit of reavers is wiped out, and I lose four more guard. the basi drops khorgorath down to half wounds and the lose two in return. in my turn kroak croak casts celestial deliverance twice (buffed by the astrolith ) and kills the blood stoker, two reavers and drops three wounds of the khorgorath. comets call then kills five reavers, due my double six casting and a mystic shield goes up on the temple guard. kroak is a beast. in combat he decides to attack my astrolith, and almost kills it. one wound left. I wipe the second unit of blood reavers and the basi claims the second khorgorath. yay!
unfortunately ,the game had to end there as the store we played at had to close. we both shook hands and agreed on a draw. I think that went well
Khorne:
20 blood reavers
20 blood reavers
10 blood warriors
2 khorgoraths
1 bloodsecrator
1 bloodstoker
Seraphon:
15 temple guard
10 chameleon skinks
lord kroak
asrolith bearer
bastilidon
turn one:
