Skink Chief
Mr Phat
9th Age Army Support
Greetings AoS'ian Spawnings!
Tidings from 9th age!
I have ventured forth into your realm, to seek knowledge on your way of life!
But to the point.
To me AoS has come and gone.
I was initially a hater.
Then a lover.
Then a hater again.
Then an attempting lover
and then a stranger as 9th gave me catharsis to the whole situation.
In my opinion AoS it is the best that have ever happened to warhammer,
for that sole reason that it force the birth of 9th age, which (to me) is superior to anything 8th ever was.
And now that the community have endured the culmination, now that the dust has settled and my feelings
have gone cold blooded again... I am ready to once again look upon Age Of Sigmar with an open mind..
and that I am for one reason only:
It is no longer forced upon me as a substitute for the game I love, it is something I can CHOOSE to play on the side without giving up Warhammer as I know it best.
On that note I have questions for you:
1. Has the balance problem been solved? are there a way to have an even game which is the
generally accepted way to build lists?
2. The base contra model measuring: how do you do it now?
Are you still measuring from the model as the game suggest
(which creates enormous problems with alternate models or conversions)
or are you measuring from bases?
(which creates the proble of Square contra Oval bases)
3. Have you discovered any kind of game depth that game was initially condemned for not having?
I've had 3 games and every one of them ended the same: cluster-combat in the middle of the table, decided entirely by dice.
Have a meta strategy evolved since then?
4. I know there is a novel describing in detail how the Lizardmen became the Seraphon,
and what happened between the end times and present times. What is the name of it?
5. How have you dealt with the overwhelming (and highly unfair) strength of Summoning?
I hope that you can help me find the general structure of what AoS has become, as it must surely have
evolved since its birth
Thanks in advance.
But to the point.
Then a lover.
Then a hater again.
Thanks in advance.
