skink chief
I'm just going to go over them one more time. To see what questions I have.
So the attributes of a lore... they stack right?
because:
Beasts: Target has +1 Strength or +1 Attack.
With beast of horros gone,...
Death:
Target suffers 1 wound with no armour save allowed. If a wound is dealt, the caster recovers 1 wound.
You can actually blow up a character with 3wounds by getting 3 spells of from death? Seems Very strong to me, granted range is only 12''
Heavens:
Active player is allowed to reroll a single dice this magic phase, either a Power dice, a dice for number of
hits or a to wound roll.
So this one says reroll a single dice THIS MP! So this one does not stack?
Metal: Target has +1 armour save.
This one is not focused so this one can go on an entire unit and be stacked... (temporarely, but still).
Shadow: Target may perform a 10” Flying Magical Move.
Behind enemy lines after 2-3 spells go off xD.
Surely I must have mist some rules that say attributes only go off once, no?
If I did not miss that rule and it can be stacked ( exept for heavens apparently), the attributes are stronger then the spells imo
Again really like the spells, but the attributes... someone explain pls
I can deal with most of them, but death and shadow ... wauwza
because:
Death:
Heavens:
