AoS AoS - Did You Know That... ?
Haha it's ok. 25 years old and I still can't beat this game:
I've done it a few times, But I forgot where you are supposed to start (empty peg).
  • Like
Reactions: Ixt
I do recall that leaving pegs in the corners was bad.
  • Like
Reactions: Ixt
Did you know that AoS... "DOES NOT SERVE -- IT RULES!?"
:p
Did you know that no models were harmed in the play-testing process for AoS?
Skavenslaves - Every slave that pops in the battleshock phase (with bravery 3) has a 1/6 chance of auto wounding the nearest unit (ie you.) If that 100 model unit takes 20 wounds to shooting and combat in your round, you haven't reduced its combat effectiveness or staying power, and you've got 3-4 MW coming back at you.
Did you know AoS finally gave Bob a chance to remind me that I was super drunk and thought it would be a good idea to submit a short story
  • Like
Reactions: Ixt
Did you know that NOT harming models is a symptom of GW NOT play testing AoS?
And @Madrck broke the thread rule too. AoS causing drunken short story submitting is surely a good thing. Just check out "The Beginning" by @Fhanados. Intro to his latest chapter. He must have been on something.
Did you know that Night goblin fanatics will be wrecking balls? Any number of models deployed from hiding at the beginning of the charge phase with 2.6x -2 rend wounds per model. They are now guided missiles every movement and charge phase (with a 1/6 comical self emasculation tax only on the movement phase) Ouch.
Did you know that because of AoS I've been out of the loop for a little while and had no idea whether what I'd done was a good or a bad thing.
I'll def check out the other story when I get a chance
Did you know the Age of Sigmar promised me that the trucks would be waiting at the dropzone?
Did you know that Arkhan can destroy any unit with a lucky series of roles? With Curse of Years, you roll ten dice, wounding on 6, then rerolling wounds needing 5s and so on. If you get even one die down to 2s and then wound, the entire rest of the unit dies as it never says that 1s fail to wound.
Did you know that AoS has crossed the species barrier?
One simple thread rule. So simple, even a panda could follow it, but no.
Sigh.
  • Like
Reactions: Ixt
Pandas don't follow any rules but their own. You can stuff your rules in your eggshell you...blue...ehhhh...thunk.
EDIT: Did you know AoS got me so upset I broke my sobriety pledge and went back to fermented bamboo?
Did you know that AoS marketing & production costs rival the cost to genetically engineer you very own Cold One!?
Which would you pick? :smuggrin:
