pendrake
No.Is your response because you believe 3 points is bettter?
I have no basis at all for an opinion on the total value OR the individual point cost of a Saurus unit or its members.
I am asking did you simply choose a number or did you do calculations or math analysis?I'm not sure what you're point is exactly.
I looks like your process is to mentally multiply [STARTING UNIT SIZE] X [b] = [TOTAL POINTS REDUCTION, TPR]
Where b is an arbitrarily chosen test number. (A guess.) Then you compare the TPR to an unstated, subjective criteria and either decide the reduction is too much/too little.
So, a lot of the first and a tiny bit of the second, based on this portion of your post:
...a squad of 30 would be almost a hundred points less.
