When I was in Architecture school, we had a laser cutter for knocking out windows and such.
That would do the trick for sure!!!
Thank you very much Crowsfoot! It's almost finished (but no painted models to put in itLooking good!
Thank you very much Crowsfoot! It's almost finished (but no painted models to put in it).
hahahaMake me 2 and l will put my skinks in them![]()
If it ain't broke, don't fix it!Here is my woodwork story: i ordered skirmish bases at warbases.co.uk![]()
Yikes... what happened?My last run in with wood (actually rotan) ended with heavy antibiotics, xrays, and a lot of gross stuff. And i wasnt even trying to make something, i just went for lunch.
Not much, i just bumped a rotan chair my foot. Thought i just cut my self, but after like three weeks a 4 cm long an 5 mm thick splinter came out. Still really cant believe you can get a splinter this big in to yourself without seeing anything.
I think what we've all learned from this thread is that no-one on this forum should really work with/nearby wood except got Nightbringer![]()
The injury I told you all about was one of my minor ones, I've lost the top off a finger, nearly cut my thumb off, the list is endless, not all done working with wood, I had a aluminium splinter once that went in the palm of my hand and came out the opposite side, that hurt like hell pulling it out.
http://s1008.photobucket.com/user/mottdon/media/clamps_futurama_zpsrmjr2sk1.gif.html
That's too funny. I be honest, some of the more dangerous power tools freak me out a bit. All the tools I use are on the safer side (scroll saw, drill press, dremel/rotary tool). These tools can hurt you no doubt, but they don't remove fingers like a table saw would.I think what we've all learned from this thread is that no-one on this forum should really work with/nearby wood except for Nightbringer![]()
Ouch... reading about your aluminum "splinter" made me cringe!The injury I told you all about was one of my minor ones, I've lost the top off a finger, nearly cut my thumb off, the list is endless, not all done working with wood, I had a aluminium splinter once that went in the palm of my hand and came out the opposite side, that hurt like hell pulling it out.
Thank you!They look amazing! I feel like there should be little trophies in each of the squares!
That's an interesting idea and something I've contemplated doing. It would definitely speed things up immensely. I may switch to this strategy someday, but for now I haven't because it does have a couple of downsides...I wonder if it would be easier to just add a layer of sheet metal between the wood layers ?
(rather then cutting out all those squares)
