It does it on its own. GW has several technical paints across a range of colours that crackle like that (I'm sure several other paint companies have such paint ranges too). For Chaos Dwarfs you might be interested in Mordant Earth.Does Agrellan Earth naturally do the cracking effect? Or did you do that?
It would be ideal for the bases of my upcoming Chaos Dwarf painting project...
https://citadelcolour.com/playlist/6038720983001/6038909793001
A neat trick to do is to paint a lava pattern on your base and then put the crackle paint over it. When it cracks, you'll see the lava underneath.
If you want larger cracks, I find that putting down a layer of PVA glue before the crackle paint helps!
