AoS Compilation of GHB2017 for Seraphon
Discussion in 'Seraphon Discussion' started by Kadanga, Aug 22, 2017.
  1. skipperyoss
    skipperyoss Active Member
    Like he always should've had!
    Dracoths Tail battalion looks amazing, a free 15" move for all our saurus is a dream come true since the knights can't even march that far. Summon a balewind and suddenly you can deploy anywhere via summoning. Take the double teleport command trait on the Slann and enjoy unparalleled movement unless you're fighting a wanderers player near a table edge.
    Dissapointed by the lack of healing options for our big monsters, wish we had something there. I'm really excited to test the Tail formation though.
    Ritual and Kadanga like this.
  2. Killer Angel
    A melee hero got better items to deal damage or increase survival chances. An item that maybe does d3 is a poor choice for a meleer (IMO)
    Ritual likes this.
  3. KingCheops
    KingCheops Active Member
    But you can now only ever have 1 copy of an item in a list and if you are playing Seraphon allegiance you are limited to those 6 items. So after the shield and the blade what do you take?
    Ritual likes this.
  4. Nielspeterdejong
    Nielspeterdejong Well-Known Member
    Can anyone confirm how item 2 works? Say you get a type of weapon against you of which 3 attacks hit for 2 damage each, and you had 3 health left: Do you then ignore the 6 total damage of that weapon as it would lower you to 0 and more, and instead now have 3+D3 wounds? With only a once per battle use?
    Provided you rolled a 3+ ofcourse.
    Ritual likes this.
  5. Aginor
    As I read it it doesn't matter how many wounda you get. When something drops you to zero or below, you roll a dice. On a 3 or more you are teleported up to 12" away if possible and heal d3 wounds.
    Ritual likes this.
  6. Mark Sinosich
    Mark Sinosich Active Member
    Like a large number of GW rules, it is open to interpretation and will be debated till a FAQ comes out.
    I feel its "intent" was to resurrect up to D3 wounds after taking any number of fatal wounds. Rules lawyers will certainly argue different.
    Ritual likes this.
  7. Mark Sinosich
    If you are Seraphon Allegiance you are still Order Allegiance and cant take Order Artifacts. Right?
    Ecozh and Ritual like this.
  8. Aginor
    I am pretty sure that's the case. Ironjawz can take Battlebrew despite having IJ allegiance. Same thing.
    Ritual likes this.
  9. Killer Angel
    As already answered, we can take also Order artefact.
    Seraphage and Ritual like this.
  10. scubrat
    scubrat Well-Known Member
    I thought you had to pick one or the other allegiance? So we can still take a quicksilver along with our seraphon artefacts?
    Ritual likes this.
  11. Killer Angel
    It was FAQd.
    You can always choose traits and artefacts from the Grand Allegiance you belong to.
  12. crazyhorse1321
    crazyhorse1321 Member
    That is true but you can't mix the 2. You either take the Order trait and artifacts or you take the Seraphon traits and artifacts. You CAN"T take Seraphon trait and order artifacts.
  13. Aginor
    Really? Do you have a source for that?
  14. Seraphage
    Stegadon
    Seraphage Well-Known Member
    Are you sure ? I thought that was the question that got FAQed and the answer was yes ?
  15. scubrat
    In this FAQ it states, "You can choose to take either the allegiance abilities for the allegiance your army belongs to, or the allegiance abilities for the Grand Alliance your army belongs to."
    To me that sounds like you can only take Seraphon traits and artefacts or Order ones, not both in the same list.
    Ecozh likes this.
  16. crazyhorse1321
    Thats how I read it as well.
  17. Gradeaal
    Gradeaal Member
    The goal of this was to allow battletomeless allegiances or those without abilities to keep up with bonesplitterz, sylvaneth, beastclaw and be able to use their unique battleline units. With all the new goodies we have it makes more sense to use our own artifacts and abilities now that weve received the upgrade.
  18. Seraphage
    Stegadon
    Ah that is unfortunate. Yes, the case seems to be what you said. No quicksilver potion I guess !
  19. Aginor
    Well... it only mentions abilities, not artefacts, so.....
    scubrat likes this.
  20. scubrat
    True, ah, it's a bit sketchy, I mean, you could think they meant to add artefacts and traits in there too but it could be that they excluded them because whilst you would gain an advantage for having two allegiance abilities you wouldn't necessarily gain that same advantage for artefacts and traits because you can't stack those.
