Tutorial A Guide to Seraphon Battalions - GHB2017
Discussion in 'Seraphon Tactics' started by Killer Angel, Sep 8, 2017.
  1. Canas
    Canas Ninth Spawning
    Sounds like this is another example where seraphon ended up getting screwed over in an effort to balance the overpowered once as we seem to have been designed before anyone ever thought of these issues. Rule of one for magic, point costs for summoning, the limit on behemoths & the costs of battalions, they all seem to hit us far harder than some other armies or at th least we seem to be build around these specific mechanics to a much larger degree than the others. I do hope they'l look into that for the next GHB (or just give us some new stuff :p)
    As for the advantage it gives during set-up, this just seems like the way of determining who goes first just didn't turn out particularly well in hindsight. If only cuz it gives a weird incentive to using as few units as possible. Even without battalion shenenigans, fielding 1 unit of 20 now has a setup advantage over 2 units of 10 despite the 2 units being able to field more special stuff & being more mobile as it's spit. Which is a tad weird.
  2. Xasto
    Xasto Well-Known Member
    This. SO much this.
  3. Killer Angel
    I suggest to discuss the general cost of battalions in the specific thread made by @Canas for this issue... ;)
    Paul Beenis likes this.
  4. Paul Beenis
    Paul Beenis Active Member
    Thanks @Killer Angel for the addition of Heavenswatch to your guide! Looking forward to thinking over it more and seeing whether I can build a decent list with it.
    Killer Angel likes this.
  5. Killer Angel
    Glad you liked it. The purpose of this thread is to give some help to anyone that wants to play our Starhosts! ;)
    Paul Beenis and Aginor like this.
  6. Killer Angel
    Time to analyze the battalions included in the GHB2017!
    DRACOTHION'S TAIL
    UNITS REQUIRED:
    1 Slann Starmaster (Kuoteq)
    1 Firelance Starhost
    plus:
    0-4 battalions from: Sunclaw, Eternal, Firelance, Shadowstrike
    any number of additional Seraphon units (this one is very important)
    The Starhost gives:
    - in the hero phase, Kuoteq can cast any number of summoning spells that summon saurus units to the battlefield as long as each unit he summons comes from this battalion, without need to roll. The casting is automatically successful, cannot be unbinded and doesn't count toward the number of spells that can be cast by the Slann. The same summoning spell cannot be cast twice in the same turn.
    This seems insanely good and comes at only 100 pts, however there are 2 big limitations:
    1) the free summoning is only for units with the "SAURUS" keyword. No skinks or dinosaurs with the skink keyword... it's hampering but we can work around it
    2) it's not totally clear if you can insert a 40 sauri block and summon them. IMO it's still a summon spell, so you must follow the limitations of summoning: basic summon for saurus warriors is a 10 unit, if you roll 11+ you can field 20, so you can call a 20 saurus unit, but that would be the limit, no way you can call that big horde of 40 Sauri from a Sunclaw starhost.
    If the latter is true you can still work around it.
    the third limitation is that the starting point is the Firelance Starhost, which is not our best battalion.
    HOW TO MAKE IT WORK​
    The starhost should work nicely starting from 2000 pts.
    The Starhost can include any number of SERAPHON units so you can form your army as you want (no ally), regardless the number of points, and can deploy it in a single drop, with some units on the battlefield and some other waiting to be summoned. This means that 99% you will have the initiative in the first turn, and that's not a small thing, as it gives you the first alpha strike.
    It's not required for the Slann Kuoteq to be the general. This gives you the freedom to pick the saurus general you like, while enjoining the bonus granted by the constellation (especially good the rerolls of 1s or +1 to charge).
    At this point, you must focus on the strenghts of the Starhost:
    You work a lot with free summonings, so you need to expand the range of your spells: Balewind Vortex, Astrolith Bearer...
    You will have a great mobility (summonings by formation, summonings by reserve pool, teleport), so you will play on objectives control, while the bulk of your army attacks the enemy.
    Your army will be sauri focused, so melee oriented: play on alpha strike waves. Hit hard your enemy since the very first turn.
    All of these things can be obtained in a number of ways, I'll now give some starting ideas / examples, but you can easily develope your own ones.
    First turn (constellation with rerolls of 1s):
    Summoning from formation: place 10 sauri knights at 9" from enemy
    Summoning from formation: place the ScarVet to give them +3" to charge
    teleport a skink starpriest already on the battlefield near them.
    shield, starlight and serpent's staff on the sauri: charge and enjoy 40 bites attacks that threaten double damage for each 6
    Second turn:
    after the enemy's turn, your first unit will be reduced in mumber; teleport them away upon an objective. Summoning from formation, place the second units of knights and repeat the assault.
    or
    First Turn (constellation with +1 to charge):
    Summoning from formation: place the ScarVet on carno to give them +3" to charge
    Summoning from reserve pool: place a bastiladon with ark of Sotek
    Teleport a Stegadon already on the battlefield and move the bastiladon with the skink Alpha
    Charge with the knights, the basti and the Carno, spam mortal wounds, force multiple bravery tests exploiting the Bloodroar
    or
    First turn (if you play with Sunclaw):
    teleport 40 saurus warriors that were already on the battlefield during the setup
    Summoning from formation: the Sunblood
    Second turn:
    move your block of warriors and charge with them
    or (especially useful if the enemy is scattered on the battlefield and you want to do multiple combats at once)
    first turn
    Summoning from formation: place 10 sauri knights at 9" from enemy (target one)
    teleport a Group of 20 Saurus guards that were already on the battlefield, buffed with mystic shield, at 9" from the enemy (target 2)
    Summoning from formation: Eternity warden
    Summoning from formation: Saurus Oldblood as general, move by 3" the Guards.
    Charge at 6" (5" with constellation) with both knights and guards; guards save at 2+ so use firstly the knights.
    Or
    go with the knights, and teleport a unit of 4 razordons to support with short range shooting.
    FINAL NOTE:
    as said, your entire army can be included in the Tail, however you are forced to take only a Slann and the Firelance (including the battalion cost, this alone will take you probably over 1000 pts).
    Other chances offered by the Tail are other melee-focused starhosts, so it's interesting to see what kind of other units you need to insert in the Tail. I will focus on non-sauri units, that must be placed on the battlefield... this is not a complete list, pick the ones you think you need more, or some other ones that I have not listed but you think they could work.
    Magic support: probably the Slann won't be the general, so no Vast Intellect. You will need a Starpriest to have Starlight, the Serpent's staff for the knights / carnosaur, and a Vassal for the Slann. 80 pts well spent, place it on the battlefield since the beginning
    Shooting: groups of razordons and Salamanders are always handy to some short range support, especially when you can teleport them near the enemy lines (for sallies, remember that you need handlers to have 12" range).
    Other: dinosaurs are a classic and their contribute is solid. Bastiladon with ark (for MW spam) or with Solar Ray (for more shooting); Basti can be reliably summoned with reserve pool. Stegadon it's harder to summon, so it must be placed on the battlefield in the setup, but gives strong melee and some shooting too.
    EVALUATION:
    Power level: mid / mid-high
    It's an army that's focused on melee but that can have any seraphon unit, including the support units you may need, so it offers a sufficient flexibility.
    However, the starhost comes with several limitations and tax units, so you must be aware of them and of the ways you have to bypass / mitigate those disadvantages, to employ the Starhost in an efficient way.
    You can find hard times against certain armies, especially the ones that can play your own game and got range too (SCE, Sylvaneth and similar), and some scenarios with just a couple of objectives won't favor you; anyway, the free summoning and the possibility to end your "deployment" in a single drop, are powerful tools.
    DarkMatter likes this.
  7. Canas
    Wasn't the idea that these summoning spells were essentially just a sort of lightning strike ability? So that you could summon that block of 40 if you wanted to as long as you predefine that this as part of the battalion? I vaguely remember a discussion about it on here but can't find it.
    Also, the biggest drawback is probably that summoning isn't all that good, and the only bonus it gives is the succesfull summons. If our charges were more reliable or we could summon closer it'd be extremely good. But right now it seems like it'd mostly drops your stuff just out of range. Might still be quicker than walking through a hailfire of arrows while trying to attack, but doesn't seem too amazing.
    Killer Angel and Seraphage like this.
  8. Killer Angel
    Yes it was an interpretation, but afaik there is not an official clarification on this, so i wanted to err on the side of caution.
    Do you think i should clarify it in the analysis?
    Edit: done. This way i have specified that there is a doubt
    Canas likes this.
  9. Canas
    Given that it does say that the summons are guaranteed to work it'd be weird to have the super effective summons on a 11+, so I'd lean towards glorified lightningstrike. But if there's still no official ruling it does remain a bit unclear...
    Also, might be interesting to go into what stuff to bring as support outside of the battalion. Especially if they're just normal summons this becomes very relevant as then all it does is guarantee your summons for these units are succesfull but does nothing more. So you'l want support from something.
  10. Killer Angel
    It may be of some help. Updated the post ;)
    Aginor likes this.
  11. Hankster
    Hankster Member
    Hey Killer Angle,
    Great work on all these battalion summaries! They are super helpful for a newcomer like me.
    I really like the look of the thunderquake starhost. I'm new to AoS and just starting to build my Seraphon army. If I was to use the thunderquake as my core, what would be the best compliments?
    It sounds like I would need a Slann and couple of units of Skinks. Would ripperdactals work too? It seems like their ability to just delete a unit would be a nice complement to the block of big boys.
    Would you suggest a specific combination for a beginner? E.g. take the EoTG over the Troglodon or vice versa?
    Thanks!
    Seraphage likes this.
  12. Killer Angel
    Hi, glad to be helpful!
    Keep in mind that ALL these analysis should be re-evaluated with the new 2nd edition.
    The new points, rules and most of all the mechanic of summoning, change the way of playing.
    And this without even touching the wholeness of endless spells.
    Even a specific thing as rippers, must be viewed keeping in mind that their warscroll has been updated.
    Anyway, actually the EotG is one of our strongest unit (exactly for the chance to summon free reinforcements), so i wouldn't consider a thunderquake without engine. ;)
    Buldi and Hankster like this.
  13. Hankster
    Hankster Member
    Thanks, I was thinking the EotG was the way to go. It seems like with a Slann and a EotG you could summon spam enough units to be a real pain in any area control game. Admittedly, I have never actually played, but on paper at least the Slann's summoning ability seems like it should be the core of any Seraphon army.
  14. Killer Angel
    Yeah, pretty much.
    Summoning (on various degrees) is a tool too much useful to be ignored.
    Now that i'm here, i think i will edit the title of the thread, as it was made for ghb2017
    Seraphage and Hankster like this.
  15. Hankster
    Hankster Member
    Is it a good idea to combine the thunderquake shadowstrike battalions? Together they basically make up the army I was thinking of making.
  16. Crowsfoot
    Both are strong and with summoning you can bring in cheap troops so yeah I would say so, or be really nasty and go double Shadowstrike.
    Hankster likes this.
  17. Hankster
    Hankster Member
    With all those rippers? That would be nasty!
    Thanks for the help. I've started ordering units now so soon the grand painting will begin. :)
    Koriialstraz and Crowsfoot like this.
  18. Crowsfoot
    Start a blog so I can keep an eye on it.
    Koriialstraz likes this.
  19. Canas
    mwha, most of our battalions won't have changed much with the new rules. Most of the new rules simply don't directly influence much that has to do with our battalions (unlike how they would in say a shooty army).I'd wager the majority of what's written here still basically holds.
    As for the thunderquake, it's not so much that the EoTG is good, it's more that there's no real reason to ever take a troglodon which already makes the EoTG the default pick unless you've run out of points..
  20. ILKAIN
    Skink Chief
    ILKAIN Well-Known Member
    Are Trog's that useless? Why?
