little-myth
Fluff is in rough draft, just getting this out the way for the moment.
Fluff:
Ataxa was once a Scar-Veteran leading his unit of troop into battle against Chaos; marked by Tzeentch. When the troops charged into combat against the Chosen; Ataxa readied himself to challenge the champion while the rest of the Saurus battles the rest.
During the challenge the champion landed his great weapon sharply onto Ataxa's shield, cutting into the hide. Ataxa roared out and tore is shield away, staring for a brief moment at his shield. He slipped the shield down is disgust, letting it fall to the ground. The champion readied another strike, slamming down with all force. Ataxa used his sword to defend against the blow, slowly being pushed down as the champion tries break through his defence, He tried to think as fast as he can. Looking around franticly in hopes his mind would come up with a tactic. He spots one of his fallen comrades swords, using his tail he scooped up the blade and quickly grabs it into one of his hands, causing him to take a hit from the great sword, he was lucky his armour and skin reduced some of blow. Ataxa straightened back up and roars out his battle cry, lunging with heavy force into the champion. He slashed against champions revealed neck with the two blades with ferocity.
During the battle the god, Tzeentch was watching carefully over the scener, snickering at how Saurus's reflexes are very sluggish. Then he took note on Ataxa; who was charging towards Chaos. Tzeentch couldn't help but to smile, what if he was to mess with this one Saurus's mind? Fill his mind with many thoughts and such? He knew well if the Saurus's learned to cope he would put Chaos at risk, but it was all too much to resist to see a more flexible Saurus ending up dying from trying to figure out what was going on. He made his final desicion and raised his hand up with a slight flick.
After a while since the battle against Chaos, Ataxa had to lead a group down to the ruined city to clear out some Skaven. On the way down, he had moments where he had to stop and look around for a bit, he felt strange thoughts lurking around, even for days he had to stop what he was doing and take a moment to collect his mind. When they reached the city they went around for a bit in hopes to find at least one Skaven to pound into the ground. When Ataxa strides out more into the open area, three Clanrats leaped out and latched onto him, he quickly reacted and threw them off. They hissed at him and scuttled closer. He readied his spear and warns them with a grunt. He suddenly lost it and bellows out, he felt anger grip him all the sudden in such a short burst. He snaps his spear into two with a quick flick of his wrists and slams the rats across the ground with brute force from the combo of his fists and broken spear ends. The troop soon piled in to fend off the Skaven but only to find Ataxa striding around, trying to let some of the tantrum out.
Ataxa soon found out that he has been cursed by Tzeentch, Skink Priests were not sure if this was a blessing or curse. He was been afflicted both in his thoughts and emotions, well what emotions he has got, making him either stop to gather his mind or react powerfully.
Ataxa spent many moons trying to master his curse but to only find that it cannot be fully controlled at will, he also started to wield an additional hand weapon as a reminder about his curse, both his blades a gift and his armour being he abandoned his shield. Also over the time his body developed blue markings to show the curse slowly gripping him. Ataxa still carries on leading his troops into many battles, sometimes dragging them inappropriately from his frenzied anger.
Ataxa the Great Accursed one- 215 points (Based on a Scar-Veteran)
M WS BS S T W I A Ld
4 5 0 5 5 2 4 4 8
Equipment:
Magic Weapon (Dual Blades) Gives Ataxa +d3 attacks in combat instead of the usual +1 for having two weapons. In addition, Ataxa gains an additional attack from his Predatory Fighter rule on any successful To Hit rolls of 5 or 6.
Light Armour
Magic Armour. Give 5+ ward save.
Rules:
Cold-blooded, Predatory Fighter.
Scaly Skin (5+)
Blind Rage:
When Ataxa generates attacks using his Predatory Fighter Special Rule, any missed rolls on to hit automatically hits a member of his own unit. These attacks are distributed as per shooting. Ataxa cannot hit himself with these attacks and if he is on his own, these attacks instead just miss.
(Will test this out to see how this works)
Curse rule:
At the start of each friendly movement phase, roll a D6 and consult the table to see the result, the effect from the table lasts until the next friendly movement phase.
1- Gains the Stupidity rule
2- Suffers a -D3 to Weapon skill
3-4 Gains the Frenzy rule
5- Gains the Always Strikes First rule
6- Gains the Killing Blow rule
Fluff:
4 5 0 5 5 2 4 4 8
Equipment:
Light Armour
Rules:
Scaly Skin (5+)
Blind Rage:
Curse rule:
