Chameleon Skink
Lambs and Lions
With the hype of the new book, one list has overshadowed most others in discussion and that list is the Trog Bomb / CCP Engine.
What is Trog Bomb?
Trog Bomb is a starborne list that contains Lord Kroak and Skink Oracle of Troglodon. Using the heroic action Spatial Translocation, Lord Kroak can teleport the troglodon 9" away from the enemy and channel his signature spell, Celestial Deliverance, to do D3 MWs to 3 targets a total of 4 times. This averages out to 24MWs total (min 12 max 36) or 8MWs to a single target (min 4 max 12).
What is CPP Engine?
CPP Engine is Trog Bomb with the addition of a Slann Starmaster with the Lord of Celestial Resonance command trait. This allows the Slann to generate 7 CPP on your turn and possibly a more on your opponents. As Trog Bomb and CPP Engine are light on bodies summoning is important to hold objectives and prevent your castle from bing over run.
What does the basic list look like?
Lord Kroak 395
Skink Oracle on Troglodon 270
Saurus Astrolith Bearer 140
Slann Starmaster 275
Chronomantic Cogs 70
___________________total 1150
850pts of other stuff
As you can see the list is very hero heavy and wound light. Many people also choose to add skink starpriest or starseer. A unit or two of saurus guard are almost mandatory. But 850pts is all you get to play with for the rest of your army.
What are the strengths of the list?
MWs, MWs and MWs. This list can pump out a ton of targeted MWs just about anywhere on the table turn one. Killing support heroes with ease can cripple many armies and ruin key strategies. Summoning allows for some flexibility. Each CPP is worth about 10pts and you can generate several hundred points of models over the course of the game.
What are the weaknesses of the list?
Low model count and defensively weak casters means fast armies can be troubling. Large heroes that can't be killed in a single round. Ward saves are annoying.
Major weaknesses are Teclis who can reflect magic back at you and Khorne who gets blood tithe from our spells and can become immune to magic.
Major points of Discussion:
How are you spending your 850pts?
What are you summoning with your CPP?
What is your plan against Teclis and Khorne?
How have your games been going?
What is Trog Bomb?
What is CPP Engine?
Lord Kroak 395
