TOW Ruby Ring in temple guard champion? Worth it? (renegade)
Ripperdactyl
Kalisto
460
186
43
I want to try a new list with slann and 2 carnosaurs. As you can image the points are not enough to have also a ruby ring in heroes (i prefer a BSB and a ward save for both heroes).
Now the question is, do you think it's worth to have the ruby ring on temple guard champion? I should just remove 4 skinks to make place for it.
Usually I don't play it on a Slann since he has to be inside dispel range of level 4, this mean usually it don't go through. However maybe the champion could be just outside the dispel range (by like 1-2") for 1 or 2 round.
Have anyone of you tried? What do you think about it?
The main issue is that you can only move 4" if you want to use it
I don’t think it’s really worth the points to be honest. With the current focus in the meta being large blocks of infantry, and Temple Guard being the best option of this for Lizardmen, you’d want to get them at least partway up the table ASAP.
This means you’ll very quickly be within dispel range, and the RROR being a low level bound fireball, it seems like a waste of points.
My list often includes a Slann, Ancient Steg and a Bastiladon so I’m already tooled up with some decent(ish) bound spells to run alongside my wizard’s magic. Personally, I’d equip the Temple Guard champion with the Spelleater Axe instead for the magic resistance(2) or possibly the Staff of the Lost Sun.
