AoS Reroll help
Star Dino
17
8
Quick question regarding re-rolling.
When a spell or ability says reroll hit rolls of 1, does that mean on first throw you gather the ones and reroll them once?
Or does it mean you keep rerolling any hit rolls of 1. (If your reroll is 1, you reroll until you get something other than 1)?
When i last battled we did it the first way but now Im thinking that its wrong.
You cannot reroll any roll more than once. Rerolling 1's means that you cannot reroll any other result, like 2s, 3s, etc.
Yep, also check if it says "unmodified rolls" or not, some abilities do it differently than others.
So if i have great drake constellation from my slann, everytime i get a 1 on first throws for hit, i can reroll the 1's once.
Is it stackable? like if i had the constelation and ripperdactyls swooping dive to reroll failed hit rolls?
Or the cannot reroll any roll more than once a constant?
You can only reroll each dice once, it does not stack.
Any single dice can always be rerolled once, regardless of how many sources provide you with rerolls.
So for example if you have an Astrolith Bearer in range, granting rerolls for all hits, and Skink Handlers that allow a Razordon to reroll hit rolls of 1 in the shooting phase, then you just choose one. (in that case the Astrolith's because it is better)
