Kinslayer
Hi guys, it has been a little while since I played warhammer at all but I used to play Lizardmen in 6th as well as other armies. I have played 8th edition but only using Vampire Counts, before their 8th edition book. Now I am looking to start over and collect fantasy again with the Lizardmen. I've already ordered the bulk of an army but I am having some trouble putting those models into a decent list. I've also struggled to keep to the points limit when including everything I want to use, despite the fact I've read all the tacticas and advice given on this forum to help me come up with a list.
I'd like to stay away from metal models / models that will likely be redone with the eventual 8th edition upgrade. This is why I did not yet include a Slann although I suppose it will be resin cast sooner or later. I also really like the carnosaur and it is something I never played in 6th edition, so I wanted to give that a go. The first list I drew up was way over my points limit, so I had to drop out the cavalry all together and some of the skinks. The trouble I am having is this has left me with a list that looks nothing like the saurus heavy army I had imagined, so maybe that list is just not possible?
Also this does not have to be 2000 points, I will have enough models to play 2500 or even 3000. My opponents will vary but the main two are likely skaven and bretonnia.
I bought two battalions, a carnosaur, a stegadon & a plastic oldblood. This will give me the following;
40 saurus
20 temple guard
16 cold one cavalry
24 skinks
1 stegadon
1 skink priest
1 scar veteran
1 oldblood on carnosaur
I was going to buy the third battalion as you're essentially getting the cavalry free, but I can't even fit the 16 into my army now let alone 24. I will probably just bulk out the core with two more skink boxes (and use some to make chameleons too)
What I did want to include in an army list... carnosaur, saurus, saurus cavalry, stegadon and some magic defence.
What I think I would also like in there... kroxigor, probably in skinks, and chameleons & salamanders because they seem almost essential.
What I am not interested in using... terradons, swarms, razodons, engine of the gods, loads of skinks, or at this point a Slann.
Temple guard are really awesome, but are they worth it without the Slann? If not and I want to include them I might make it a duel Carnosaur/Slann list and take it to 3000 points.
How I invisioned the army to look based on the box sets I ordered was two units of 8 cold ones going down one flank with the carnosaur, while the stegadon and the kroxigor in skinks goes down the other to split attention. The saurus block move up and hold the centre as an anvil while the units that moved up get in the flanks of any chargers. Meanwhile some small skink units harass enemy flankers and threaten positioning, while some chameleons deal with any war machines from behind enemy lines. Making a good list around those models is what I need help with though, if the idea is even going to work? Or are saurus cavalry just too over priced?
Here are two of the character builds I was mulling over last night. Any good? I'm not a huge fan of over doing it on the characters I'd rather leave points for more units than wargear.
Saurus Oldblood – 245
Sword of Bloodshed, Carnosaur Pendant, Gamblers Armour
Carnosaur – 210
Scar Veteran – 119
Great Weapon, Light Armour, Shield, Potion of Strength
Thanks in advance for any help.
40 saurus
20 temple guard
16 cold one cavalry
24 skinks
1 stegadon
1 skink priest
1 scar veteran
Carnosaur – 210
Scar Veteran – 119
