AoS I lost a match against chaos again, but it was very enlightening
Nielspeterdejong
591
514
I had a rematch again against the chaos army with a different build, this time with some skinks in front with 2 Bastiladons behind, and with a celestial hurricanum and luminark for fun. He tore through my defences and killed all my units around the Bastiladon, but it was very enlightening.
He said I could have easily defeated him, but I was too focused on taking down his hell canon. I didn't properly move back, and sadly split. He was right in that, though the reason I went after his hell canon was because I had my skink Starseer who gave the buff from the heavenwatch starhost, and I would have a disadvantage if he died.
I liked the idea of the luminark and celestial Hurricanum, but I will keep those for my Bloodclaw army idea I think. He's right though that I could have won with my heavenwatch army with skinks battlelines with two Bastiladon and luminark + Hurricanum. But I feel that I should try to go for an army with a stronger battleline.
And this time with chameleon skinks, which I will use to kill his 3 5+ defense dwarves on his hell canon! Plus I'd love to use them :) But with 3+ hit and 4+ wound, will 5 be enough for those 3 pesky dwarves? Or will I need 10? Based on that, I have three more balanced armies in mind, and wanted to hear what people though might be good combinations?
A) Balanced army Eternal
Unit of 5 chameleon skinks= 120
Eternal Starhost= 80
Eternity Warden= 140 (rend item)
15 guards (3 units)= 300
Heavenwatch= 100
Starseer=160 (general/defense/heal)
Bastiladon Lazer= 300
Bastiladon Lazer=300
Skink priest= 100 (-1 op melee aanv)
Skink priest= 100
This army has a higher chance your chameos won't be able to take out your prime target, but I'll have the eternal Starhost and the best battlelines
B) Balanced army Assassin
Unit of 10 chameleon skinks= 240
20 guards (3 units)= 400
Heavenwatch= 100
Skink priest= 100 (-1 op melee hit)
Skink priest= 100
You won't get the Eternal Starhost bonusses, nor those of the eternity warden, but you will have 20 3+ Save guards with rerolls (10 of those 2+ Save if the starseer casts mythic shield) with still 3 Bastiladons. And 20 attacks with your chameleon Skinks).
C) Balanced army Eternal Assassin
Heavenwatch= 100
Stegadon= 260
Stegadon= 260
Stegadon= 260
Skink priest= 100
This one has both the Eternal Starhost as well as the 10 Chameo skinks. But Stegadon instead of Bastiladon. Meaning far less tanky monsters and with a weaker ranged attack.
Which of these 3 sounds the safest/strongest route to take?
Also, why aren't chameleon skinks part of the Heavenwatch starhost? O.O
Since you double-posted:
You should edit the first post in the other thread and make that thread into a proper battle report. Use the first post for listing the winning OpForce and the Force you sent against them.
All we know at this point is they had a Hellcannon.
Yeah I tried to delete the first one, but I couldn't find the option ^^; But I think your idea is a pretty sound one. I'll do that :)
