Scar-Veteran
Putzfrau
Hello Lustrians!
So i've been messing around with battalions a lot and i was curious what everyones take is. Our battalions are pretty restrictive, and while not super expensive aren't cheap either. The buffs for the most part are pretty good, but not a no-brainer at the cost. Which means you'd largely be using them to lower drops.
Seraphon seem to be a high drop army. We have a lot of buffing characters, tons of units, and fitting it all in sends drops through the roof. A single battalion helps mitigate this a little bit... but a lot of the time its just a matter of going from "i've thrown drops to the wind" to that middling 7/8ish range.
I started trying to combine battalions (as evidenced by my double sunclaw list i posted a week or so ago) and quickly ran into a problem. A lot of the coalesced battalions want a specific constellation. Thunderquake wants thunderlizards, while firelance and sunclaw both thrive in Koatl's claw. Starborne is a little more all over the place but you still probably aren't taking something like the Sunclaw Templehost in a FoS list.
Shadowstrike (at least for coalesced) is really the only battalion that can function in either constellation, so it started being my "second" battalion for lack of a better term. I've started to really come around on some of the Sunclaw/Shadowstrike or ThunderQuake/Shadowstrike lists but it's still ~300 points in just battalions.
With all that in mind, i'd love to hear your guys input.
Have you messed around with double battalion lists?
Has anyone played a game with one?
Do you think are battalions are "worth" doubling up on?
Or, is the sacrifice simply too high. Our units aren't exactly cheap, and 300 points is another fat unit on the table, or multiple buffing characters.
