Articles to print in 3D - Lizardmen / Seraphon
Hi!
I've made some 3d printed reminder cards as I have the memory of a goldfish and I keep forgetting to add my buffs when shooting/combat unless I have some kind of reminder. I started to use simple post-it but I know how to 3d model and I have a 3D printer so might as well use it and share it!
I only made the ones that take effect later in the turn. IMO, no need for such reminders for instantaneous effects like the ScarVet command abilities.
I also made some CP tokens as I don't trust myself with a counter die. I usually use it to chant a prayer or knock it over and lose count... Tokens are the way to go for me.
https://cults3d.com/fr/modèle-3d/jeu/effect-reminder-cards-cp-tokens-for-seraphons-c8dce97d282cc86adbbd
List of effects:
Blazing Starlight
Control Fate
Curse
Finest Hour
Great Drake Asterism
Hand of Glory
Herald of the Old Ones
Hunter Steed Asterism
Sage's Staff Asterism
Serpent Staff
Star Born Staff
Welcome @StarJeff ! Good to see you here!
Seems like the most likely culprit would be a bad slice, have you had the same issue on other prints?
no i haven't. Standard support failures occasionally, but that is more to do with me redoing supports on everything.
SAURIAN COLUMNS 1/2
By Ge32
Many entrances to sacred sites, in the interior of the largest Saurian cities, are adorned with rows of columns at the sides of the pathways.
15 columns completely different from each other. 3 variants of each one (healthy column, with foliage and destroyed).
(Saurian Alphabet Pack by Brimstone326)
Model01: https://cults3d.com/en/3d-model/game/saurian-columns-model-01
Model02: https://cults3d.com/en/3d-model/game/saurian-columns-model-02
Model03: https://cults3d.com/en/3d-model/game/saurian-columns-model-03
Model04: https://cults3d.com/en/3d-model/game/saurian-columns-model-04
Model05: https://cults3d.com/en/3d-model/game/saurian-columns-model-05
Model06: https://cults3d.com/en/3d-model/game/saurian-columns-model-06
Model07: https://cults3d.com/en/3d-model/game/saurian-columns-model-07
Model08: https://cults3d.com/en/3d-model/game/saurian-columns-model-08
Model09: https://cults3d.com/en/3d-model/game/saurian-columns-model-09
Model10: https://cults3d.com/en/3d-model/game/saurian-columns-model-10
SAURIAN COLUMNS 2/2
By Ge32
Model11: https://cults3d.com/en/3d-model/game/saurian-columns-model-11
Model12: https://cults3d.com/en/3d-model/game/saurian-columns-model-12
Model13: https://cults3d.com/en/3d-model/game/saurian-columns-model-13
Model14: https://cults3d.com/en/3d-model/game/saurian-columns-model-14
Model15: https://cults3d.com/en/3d-model/game/saurian-columns-model-15
having either of those sculpts in resin would be a hell of a lot better than the metal versions. I have both, and they are heavy sculpts.
Looks good so far. Make it a solid model, if you currently have any cavities.
I need to find chaos helmets that have a ball join, but where the ball join is angled so it's behind/below the head.
You can look for the 40k helmets that many add ball joints, and replace the 40k helmet with one similar to fantasy. If that is what you are looking for.
If anyone has any original ideas for creating a new palanquin, they are welcome.
I assume you're trying to look less like GW to avoid any issues?
Are wanting to go in more of a direction for classic Lizardmen or "space tech" Seraphon?
-An Aztec/Mayan calendar type circle design as the base/seat instead of the "hexagon" shape?
-A ziggurat-style palanquin like these? Maybe it's a little dull, but could be thematic?
Waw! those designs look so great!
Are they your designs?
Actually, I accept any kind of palanquin ideas, all are welcome.
