I thought that was a strange update - what was the point of it?
"BAH!" I know it might have been expected, but still "BAH!"the priest is now the hero, they did it to stop putting artifacts on the stegadons weapons. it was expected.
But since there is a priest...can Kroak cast a spell through the EotG?
GW would have to like us for that to happen.It does seem like at that price point, and the obvious EoTG nerf that it could have had the Priest keyword, give it a prayer even if making it a wizard is too much.
Then I guess an EotG is still not able to get the Master of Star Rituals trait in a Thunder Lizard army since it has a monster mount? Too bad :/
You have to take Prime Warbeast for Mounted warlord in Thunderquake Templehost. If you want MoSR for free CA, you'll have to give it to Skink Priest - there's no other options.
so in all technicality you can bring 2 EotGs nd activate them 3 times total with the thunder lizard command ability
It says in the EOTG rules "At the start of the shooting phase, you can make 1 cosmic engine roll for 1 model with this ability."so in all technicality you can bring 2 EotGs nd activate them 3 times total with the thunder lizard command ability
It does not say, "An EOTG can make 1 cosmic engine roll."
The "For 1 model with this ability" denotes that only 1 of the models can make that roll.
GW doesn't want someone bringing 5 of these and creating 2 -6 units of saurus every turn.
I know, you would be using the EotG ability once normally without a command point nd then twice with the command ability from the thunderlizerds at the end of your shooting phase but point wise it's not really worth it.
