Scar-Veteran
Sudsinabucket
Yeah, the howdah is being more tricky than I anticipated. Between the Styrofoam and just the natiral curve of the Brachio's back its a bit if a challenge.I like the troglodon and the base, but the Styrofoam for the thunderlizard's back looks too clunky to me, maybe some smaller Styrofoam like some foam board instead? Your howdah bases are so beautiful, they need to have some prettier looking supports to hold them up!
These are fantastic! Question is...how? Do you start from the center? I was thinking of having a saurus coming through. The space I'm working with is pretty small, 1" x 1.5"I REALLY like the use of that stuff for a "magic bolt" coming out the skinks hand.
But I am not sure I am feeling the swirling-mass of magic energy coming from the standard itself, is it supposed to be a portal opening? Maybe make it more swirly or something, so it looks like a portal opening?
Or you could take the crystal skull approach![]()
Lol thanks! It is kinda cute in some ways isnt it?This is so cute.
And epic.![]()
Yeah wanted to give him a unique staff (not spearNice work on the skink.
I see you exaggerated the spear
seems correct that a Skink Priest commands the TL that is ridden by lot of other skinks
Gr, Imrahil
a unique staff (not spear)
It honestly doesn't bother me but I was thinking of filling it with some liquid green stuff since the gap is small enough.You're correct, I thought to little of the Priest
I did take another look at the priest. The hand fits rather well in size, but the wrist looks a bit odd.
Don't know if it is an easy fix (and if it bothers you anything)
Gr, Imrahil
Did you paint those dots or sprinkle them (using the "toothbrush method)?
