Skaven Slave
Clan Moulder
It's not cumulative sort of thing... it is a most consecutive reps contest, in a single set.I'm rolling with it.
Good job!Finally finished my Skaven for Shadespire.
Photos?Finally finished my Skaven for Shadespire.
Explain how you did so. PleaseI fixed the wings on my old Galrauch model. Regular pinning was not good enough... I had had to go heavy duty.
Instead of using paper clips for pinning I used a wire coat hanger. It is far thicker and stronger. Also I was able to drill very deep for the pin. Lastly, for the adhesive, I used a 5 minute two part epoxy. I find the 5 minute epoxy creates an exceptionally strong bond when combined with pinning.Explain how you did so. Please
What brand of epoxy do you use?Instead of using paper clips for pinning I used a wire coat hanger. It is far thicker and stronger. Also I was able to drill very deep for the pin. Lastly, for the adhesive, I used a 5 minute two part epoxy. I find the 5 minute epoxy creates an exceptionally strong bond when combined with pinning.
The reason I had to go this route is because Galrauch has heavy pewter wings. It is a nightmare of a joint.
The one I currently have is called Adhaero. I got it because it is cheap (sold in dollar stores) and does the job. There are better ones out there though, but in my experience the cheap stuff works well enough.What brand of epoxy do you use?
I'll have to look for it.The one I currently have is called Adhaero. I got it because it is cheap (sold in dollar stores) and does the job. There are better ones out there though, but in my experience the cheap stuff works well enough.
That's an important one!So plan A for organizing the hobby area goes into effect tonight.
Yes and I think it will workThat's an important one!
In terms of appeasing the Mrs.?Yes and I think it will work
That and painting fasterIn terms of appeasing the Mrs.?![]()
Indeed. As is getting armies table readyBoth worthy goals.
They are devoid of life and characterI consider my grey models table ready!
Yea.. but they can still stomp a fully painted army into the ground!They are devoid of life and character
Throw down the gauntlet thenYea.. but they can still stomp a fully painted army into the ground!
