8th Ed. Square base question & magnets?
Discussion in 'Lizardmen & Saurian Ancients Discussion' started by LeanderAT, Sep 8, 2017.
  1. LeanderAT
    LeanderAT Member
    Hi!
    1) What's the square base size of a Salamander? 50x50mm? 60? Not the oval AoS base but the old one.
    2) What magnets are recommended to use different Stegadon tops? I also need some for the Saurus Cavalry as the riders don't fit well.
  2. n810
    n810 First Spawning
    I believe it was 50mmx50mm.
    use like 3mm rare earth magnets for stegs, and green stuff for our ill fitting cold ones.
    LeanderAT likes this.
  3. NIGHTBRINGER
    The correct base size for a Salamander is 40x40 mm.
  4. n810
    n810 First Spawning
    My bad...
  5. LeanderAT
    LeanderAT Member
    Thanks! I have some spare 40x40mm bases. I'll use some other models as salamanders then. Maybe even something with bows (only for the razor salamander of course).
  6. n810
    n810 First Spawning
    Razordons ?
  7. LeanderAT
    LeanderAT Member
    I don't know the English name. Yes, should be that model.
    [​IMG]
    n810 likes this.
  8. LeanderAT
    LeanderAT Member
    What square base size did Kroxigors and the Slann have?
    I checked some oval sizes and compared them to square bases I have at home...they were the same. Then I checked the Kroxigors and the Slann...50mm oval size...and so I ordered 50x50mm square bases for 8€. :(
  9. hardyworld
    hardyworld Active Member
    Kroxigors are 40mm x 40mm...Slann is 50mm x 50mm
    NIGHTBRINGER likes this.
  10. LeanderAT
    LeanderAT Member
    Thanks! :)
