8th Ed. SlanntaClause's Army (Work In Progress)
Discussion in 'Lizardmen & Saurian Ancients Army Lists' started by SlanntaClause, Apr 22, 2016.
  1. SlanntaClause
    My Army - list of figures:
    1 Slann Starmaster [Metal]
    1 Skink Starseer Tetto'Ekko [Poly-resin]
    1 Slann Forgeworld [Poly-resin]
    1 Saurian Mauler [Metal]
    2 Terraddons [Metal]
    2 Stegadon [1 Metal + 1 Plastic]
    2 Slann Mage Priest carried by pigmy slaves [Metal]
    3 Slann Mage Priest [Metal]
    8 Saurus Knights on Cold Ones [Plastic]
    10 Skink Archers [Plastic]
    My Army - to do list:
    - Strip painted figures
    - Glue unassembled and broken models from Ebay
    - Buy round bases for models
    Bowser, Jorgik and Warden like this.
  2. Warden
    Warden Tenth Spawning
    Looking forward to seeing pictures!!!
    Also, I think @n810 could probably come up with a fantastic avatar for you, your forum ID name has a lot of jolly potential...
    SlanntaClause, Jorgik and n810 like this.
  3. SlanntaClause
    I like that idea if he/she is up for it unfortunately I got the name change today and didn't spell check it before requesting :p I believe my name is now a joke on santa clause the movie where his name is a contract with a clause rather than Claus? but hey it'll do
  4. SlanntaClause
    I bought my Slann Starmaster and one of my stegadons painted but they are metal so I may end up stripping the paint and having a go myself - has anyone tried paint stripping before?
  5. Jorgik
    Jorgik Well-Known Member
    Yep, form metal it is extremely easy (not so much from plastic). Just mix warm water with some dishwashing liquid, place the model inside for some time and then scrap the paint on with some wire brush. If not, you can also use deoxygenated alcohol (the one for disinfecting wounds) and it will work a lot better (you would just need an old toothbrush).
    Hope it helps :)
    Warden likes this.
  6. SlanntaClause
    Thanks I will probably try that the painting of the models is good but I will likely want to theme my paint scheme so that they all look good together.
    dwarfepic likes this.
  7. Jorgik
    Oh, and may I add that if you use deoxygenated alcohol on plastic models use it only for 1-2 hours maximum. I left my models overnight and some detail (the whole face) got melted away... I think metal will be able to hold it, but I would´t leave it more than 2 hours again just in case. ;)
    SlanntaClause likes this.
  8. SlanntaClause
    Good advice thanks man :)
    Jorgik likes this.
  9. Jorgik
    Always ;)
  10. Slanputin
    Slanputin Well-Known Member
    What theme were you thinking?
  11. SlanntaClause
    It'll either be lava/volcanic themed and or some general jungle theme there are some nice bases I want from ebay that are pre set as like jungle and lava and then you just pain those too so ill probably buy them eventually
  12. SlanntaClause
    ^ as above :p
    I'm using this thread to update my army and pose questions on the initial thread with edits
  13. SlanntaClause
    Just added pictures all be it bad ones :p
  14. Warden
    Very ominous pictures... looks like the north pole also has some heretical followers!
    Crowsfoot, SlanntaClause and Bowser like this.
  15. Crowsfoot
    That is true, BUT at least we can see something now :D
    Bowser and SlanntaClause like this.
  16. SlanntaClause
    Got afew more models and afew more on the way does anyone know how easy green stuff is for novices?
    Bowser likes this.
  17. Bowser
    Bowser Third Spawning
    Green stuff is pretty easy to use I find, you will nearly always grab more than you need though!
  18. SlanntaClause
    Thanks bowser could you help me with the process of using it in laymens terms - how do you get it to become the part of the model you want or sculpt you want? do you wet it and dry it or something?
  19. Bowser
    You will definitely want it to be wet, or at least your hands and tools while working with it. You can just glue press it on while wet/soft, but makebsure yu avcount for gravity to ensure things don't droop. Or mold it and when it hardens then glue it to the model like any other bit.
  20. SlanntaClause
    Sounds good thanks :) I'm contemplating making a platform urhm palanquin thing for a custom Slann - I was gonna do lord mazdamundi but i'm considering my own character at the moment and i'll go from there - all my other frogs ahem Slanns look similar as I have afew of the same model now - so i'll be wanting to customise them to make them diffrent
    Warden, Jorgik and Bowser like this.
