Blog My Lizardmen Army (work in progress)
Discussion in 'Personal Paint Logs' started by jacintomateus, Apr 16, 2016.
  1. Crowsfoot
    Very nice, I have taken inspiration from your bases and used a similar approach on my KOW Salamander units ;)
  2. Jorgik
    Jorgik Well-Known Member
    Just amazing!!!
  3. jacintomateus
    jacintomateus Active Member
    Thanks guys!
    Glad you like the guy! (he is also happy!)
    @NIGHTBRINGER
    The scales are made using Airbrush to blend the colours and transaction to the blue skin.
    And then is just a light drybrush of lighter colours and wash.
    The scales look good because the model is very well sculpted.
    So just let the drybrush/wash do the job by you.
    Jorgik and NIGHTBRINGER like this.
  4. NIGHTBRINGER
    Your dry-brushing looks so perfect and smooth. Mine never turns out nearly so well. I often end up with a dusty/chalky effect :(
    You've definitely got some really great painting skills. I'm really enjoying your work!
    On the plus side, I did just get an airbrush for my B-day... now it is time to learn how to use it!
  5. n810
    n810 First Spawning
    You might be going a bit tooo dry.
    NIGHTBRINGER likes this.
  6. jacintomateus
    You are probably applying too much paint in each stroke of the Drybrush.
    I use little little paint each time.
    Also helps the smother effect if you use paints with a finer pigment. Like vallejo model air. (yes I use airbrush thinned paints for Drybrush :p)
    tom ndege and NIGHTBRINGER like this.
  7. Crowsfoot
    @NIGHTBRINGER Ohh Airbrush, get some pics up :)
  8. NIGHTBRINGER
    There probably won't be pictures for a while because I have absolutely no idea how to use it properly. :oops: To start I'll probably just be using it to apply base coats.
  9. Crowsfoot
    That will do.
  10. NIGHTBRINGER
  11. Bracnos
    Bracnos Well-Known Member
    ya thats pretty much what i will use my airbrush to do, i dont even have the right paint for it yet lol just using GW normal paints thinned out
  12. NIGHTBRINGER
    I'm in the same boat.
  13. Janf
    Chameleon Skink
    Janf Well-Known Member
    I really like your old blood on the cold one! He fits great and very nice painting!! :)
