8th Ed. Mag. Res. versus dwellows from below
Discussion in 'Rules Help' started by miniaturebrushwork, Sep 3, 2016.
  1. miniaturebrushwork
    miniaturebrushwork Member
    Hey, hope thats the right name for the lore of life spell. Its the last and most complex one.
    Did magic resistence count against that spell? In my opinion not because there are no saves at all allowed and it does not deal damage in the usual way, they just leave the game.
    thanks for help
    cheers
  2. NIGHTBRINGER
    You are correct, magic resistance offers no protection against the dwellers below. If you fail your strength test you are simply removed regardless of saves or remaining wounds.
  3. miniaturebrushwork
    Thanks, thats cool.
    cheers
  4. NIGHTBRINGER
    No problem! :)
    Definitely make sure you keep your Slann's unit out of this spell's range. You do not want your expensive Slann having to rely on a strength test to keep him alive. That should be priority #1 when facing dwellers.
  5. miniaturebrushwork
    Thanks but normaly I´m the one using dwellers ;)
    Last game I killed 4 ogres the ogre mage and the army general with that one, revenge for being hit by that nasty ogre
    item were all enemy mages has to test for irresistable force and my slann killed 9 of his temple guards :(
    By the way if I cast throne of thornes with irresistable force did I instandly get the 2+ save?
    thanks
  6. NIGHTBRINGER
    Yes you do! :) It's one of the FAQ questions that GW covered.
  7. Jorgik
    Jorgik Well-Known Member
    When you cast a spell with irresistible force, first comes (or is applied) the spell´s effect and once it is fully resolved, then the miscast must be rolled.
  8. miniaturebrushwork
    Thanks that is really helpful.
    cheers
    Jorgik likes this.
