    Dismiss Notice
KoW Lizardmen to Salamanders Conversion Chart
Discussion in 'Salamanders Discussion' started by Itepixcauh, Mar 31, 2016.
  1. pendrake
    pendrake Well-Known Member
    Concept wise what is a Rhinosaur?
    Quadruped?
    Biped?
    Reptile?
    Real Dino?
    Reaper has a huge chunk of metal in their Reptus army called a Krung Beast. It fits diagonally on a 51x51mm base and is mammalian (cross a bison and a water buffalo, but meaner).
  2. Crowsfoot
    I think concept wise the Rhinosaur is a larger Kaisenor and I would use a GW carnosaur for size, the metal version not the plastic one.
  3. pendrake
    And Kaisenor is Cold One/Horned One by another name.
    Been discovering that rhinosaurus is a bit of an Internet meme.
  4. Crowsfoot
    Yeah Kaisenor = cold one
  5. pendrake
    I have a pair of these:
    [​IMG]
    A WotC pre-painted plastic. If I remember correctly, they are perma-stuck to 2 inch rounds.
    Bowser likes this.
  6. Crowsfoot
    pretty cool, Rhinosaurs then?
  7. Crowsfoot
    Np will do it tonight for you, want a GW coldone side by side?
  8. BAE
    BAE Well-Known Member
    From the way I keep imaging it, my take is that it's a rhinoceros-like dinosaur - broad, stout and muscular, with a big head and a walking on all fours. There really isn't much of a description so it'll be interesting what Mantic come out with if they ever do make the models for it!
    If you wanted to be pedantic you could always look at the etymological descriptors. My girlfriend informs me that rhinoceros comes from the Greek 'rhis' (rhin-) meaning 'nose' and 'keras' meaning 'horn'. 'Sauros' was the Greek for 'lizard', so a Rhinosaur should either be a lizard with a distinctive nose, or an animal that's defining feature is a lizard-like nose (which would imply it's not a lizard as then a lizard-like nose wouldn't be distinctive. Because it's a lizard). o_O
  9. pendrake
    I'm thinking they could work.
    That is another thought I had: put two Cold Ones side-by-side connected by a small howdah to represent a Rhinosaur (there would be one lizard in the howdah).
  10. BAE
    That would be grand if you could please, thank you!
    This is exactly how I see them! Does anyone know if there are any models similar to this available from any model companies at the moment?
  11. pendrake
    Google either Centrosaurus or Rubeosaurus.
  12. BAE
    To be fair it could be any dinosaur in the Centrosaurinae family!
  13. Itepixcauh
    Itepixcauh Well-Known Member
    That look indeed really good. I'm amazed!
  14. Crowsfoot
    Here ya go,
    Bowser likes this.
  15. BAE
    Thank you, it's appreciated! So about the same thickness, maybe a *tiny* bit wider?
    Crowsfoot likes this.
  16. Crowsfoot
    About the same really
    Itepixcauh and Bowser like this.
  17. pendrake
    @Crowsfoot - is the max thickness at the rider's knees?
  18. Jack Trowell
    Jack Trowell Active Member
    Nice pic, in any case the gamezone mount is clearly bigger than the cold one, but not so much bigger that it look like a monster, so perfect for a large cavalry.
    About the D&D miniatures model, those use a soft plastic that is easy to cut, I already removed the base from a few of them with a sharp hobby knife, I even got to remove the bases under the small feets or humanoid models without problem, and if you do it well you even get the base left in case you need a round one for some other project or game.
  19. Crowsfoot
    Yes
  20. classicflava
    classicflava Active Member
    Jack Trowell and Itepixcauh like this.
