    Dismiss Notice
KoW Lizardmen to Salamanders Conversion Chart
Discussion in 'Salamanders Discussion' started by Itepixcauh, Mar 31, 2016.
  1. Itepixcauh
    Itepixcauh Well-Known Member
    Hello,
    I wanted to make a small conversion chart to use your Lizardmen as Salamanders in KoW, just remeber that this is my personal choice of units, there are no rules here as long as the models represent the spirit of the unit, so here we go:
    DIRECT EQUIVALENT:
    Salamander Primes/Unblooded - Saurus Warriors
    Ceremonial Guard - Saurus Warriors with Spears / Temple Guard
    Ancients - Temple Guard / Saurus Warriors Painted to look like they are old
    Kaisenor Lancers - Saurus Knights
    Ghekkotah Warriors - Skinks (Javelins or Hand Weapons)
    Ghekkotah Hunters - Skinks (blowpipes) / Chameleon Skinks
    Ghekkotah Skyraiders - Terradon / Ripperdactyl Riders
    Komodon - Slann Mage-Priest / Salamanders
    Tyrants - Kroxigors (For the Horde I use 3 Kroxigors and 12 Skinks in classic formation)
    Ember Sprites - Jungle Swarms
    Ankylodon Battle Platform - Stegadon / Bastiladon
    Lekelidon - Razordon
    Fire Drake - Bastiladon / Carnosaur / Troglodon
    Fire Elementals - Salamanders with handlers
    Greater Fire Elemental - Slann Mage-Priest
    Mage-Priest - Skink Priest / Saurus Conversion
    Clan Lord on Fire Drake - Carnosaur / Troglodon
    Clan Lord - Saurus Oldblood / Scar Veteran
    Battle-Captain - Saurus Oldblood / Scar Veteran
    Battle-Captain on Rhinosaur - Scar-Veteran/Oldblood on Carnosaur (Better the metal version)
    Herald - Scar-Veteran/Oldblood with Battle Standard
    Ghekkotah Clutch Warden - Skink Chief
    Ghekkotah Skylord - Skink Chief on Terradon / Ripperdactyl
    UNITS THAT REQUIRE SOME CONVERSION:
    Corsairs - They are Saurus with Pistols (Saurus Pirates actually)
    Ancients on Rhinosaur - They are Saurus on Dinosaurs bigger than the raptors but smaller than the Stegadon. They use 50x50 mm bases. You can just use a big unit of Saurus Knights though.
    As you see a lot of units can represent more than one thing, that is because sadly Mantic decided to give the army a different look but the great thing is that as long as in the table there aren't two units that look the same are represent different things they don't mind what you put on the table. For example: you couldn't use two Slanns, one to represent a Komodon and one to represent a Greater Elemental.
    Also, don't forget that you can use magic items to customize units, Terradons / Ripperdactyls are a good case in point, if you can use terradons to represent regular Skyriders and give the unit the Pipes of Terror (magic item that gives them the Brutal special rule) to represent Ripperdactyls, or don't, its your choice. Use your imagination to customize your own army and give it character.
    Thanks for reading!
    NIGHTBRINGER, Warden and Crowsfoot like this.
  2. Lord Grok Of Xillaqua
    Lord Grok Of Xillaqua Well-Known Member
    Nice conversion list. Not far off from what I had written for my units. The only difference in mine was I figured using the Salamander (rare) model from GW for Lekilodon and Razorbacks for Komodons
    Crowsfoot and Itepixcauh like this.
  3. Itepixcauh
    Problem is that the Komodon is supposed to be a BIG monster, it has height 4 that is as tall as a dragon but at the same time is not as strong or tough as a dragon so I figured that using slanns or the skink starseer was quite fitting.
  4. Lord Grok Of Xillaqua
    The Slaan works for the Komodon. Just feels strange to use the model that way after what it used to do in 8th ed. If we had a Lord Kroak model, what would be the best conversion for him?
  5. Itepixcauh
    My plan is to just use it as another Komodon, or as they are quite different models, use the regular Slann as a Komodon and Kroak as a Greater Fire Elemental, there is no real confusion between both.
    Lord Grok Of Xillaqua likes this.
  6. classicflava
    classicflava Active Member
    i like the idea of using the slann as a komodon. ive been using my bastiladon with the laser beam thingy(forget what its called lol) since its supposed to be height 4
    Itepixcauh likes this.
  7. Jack Trowell
    Jack Trowell Active Member
    Some suggestions that I have already made in other threads :
    - the old saurus warriors from 5th edition (they came in plastic in the starter box, so lots are still available) make perfect unblooded, as they are slightly smaller than modern saurus while still having a coherent theme with them.
    - Saurus corsairs could also be represented with javelins, as pistols are rulewise similar to throwing weapons with piercing(1), and salamanders should be strong enough to justify the piercing. This way if you want to keep your lizardmen army low tech theme you can still use corsairs. But of course who wouldn't like lizardmen with pistols ? :p
  8. Crowsfoot
  9. Itepixcauh
    No the mage-priest is Saurus size really, so a slann won't fit. I stand by my words and say that the best place for him is as a Greater Fire Elemental or a Komodon.
    Problem with the Komodon is that is a weak monster, I would say something like a very tall salamander really, the troglodon is just too big for me and looks too strong too. As there is no real equivalent I think that the slann or the starseer (What I use for them) fit rather well, a kind of tall thing throwing magic attacks, that is the best thing about KoW you can field anything you want as long as it fits with the spirit of the unit it represents.
    Crowsfoot likes this.
  10. Itepixcauh
    Actually a scaled down troglodon would be just the perfect fit
  11. Crowsfoot
    Yeah I've got my book and trying to pin down converts is hard, I know what the problem is I'm too used to seeing GW models as what they are but once based for KOW that will change, luckly I have 99% of my models on Sq bases :)
  12. Itepixcauh
    Just don't forget that Razordons and Salamander, if you use them as unit that has the Monster type they MUST go in a 50x50 base instead of the usual 40x40 base that GW used to put with them. The same goes for the Skyriders and Skylord.
    What I did was to order some custom cutted 40x40 to 50x50 mdf adaptators. Will take a picture and show them to you.
  13. Itepixcauh
    Here they are, they are laser cut and cheap.
  14. Crowsfoot
    they look good, I'm thinking 50x50 base will allow me to mount the handlers on ;)
    And have you got a link for the base?
  15. Itepixcauh
    Sadly he still doesn't have a web page, he does all by email and actually he lives quite near me. But if you are interested I can see if he would sell internationally, not sure though.
  16. Crowsfoot
    No problem, I can make some custom 50*50 bases (got loads of stuff lying around)
  17. Itepixcauh
    perfect
  18. Lord Grok Of Xillaqua
    So far in my group, people haven't been as strict about the monster size bases due to the difficulty of finding 50x50 bases easily but future tournaments will enforce the base size rule so i'm looking into those bases as well. otherwise the only legal monster I have is the Ankylodon Battle Platform.
  19. Itepixcauh
    Remember that bases can always be bigger that the standard size, the problem is to use bases that are smaller than the real size of the unit.
    So a Slanns can be a Mage-Priest, but it would be bad for you, that's the point.
  20. Jack Trowell
    Another option for a slann, like I suggested in another thread, is to use the profile of the mage hero from destiny of kings, he has a rather interesting twist to its magic making him special, ans as you said we can always use a bigger base if appropriate for the model.
    Crowsfoot, Bowser and Itepixcauh like this.
