AoS "How many attacks?" aka "How to read the war scrolls"
Discussion in 'Rules Help' started by Mooncrawler, Jul 5, 2015.
  1. Mooncrawler
    Mooncrawler New Member
    Hi Folks,
    I´m confused by the new easy and small rules. I don´t get it how many attacks a model really has. If I´m right, you have to read the description and the take a look at the weapon options... but...
    Example Saurus Oldblood:
    A Saurus Oldblood is a single model. It takes to the field armed with a powerful Suntooth Maul or a swift Celestite weapon – either a Warblade, War-spear or Greatblade, depending on its chosen strategies. A seasoned predator, an Oldblood also tears at its foes with its Fearsome Jaws and its Stardrake Shield, which is as deadly in offence as it is indomitable in defence.
    So what I read:
    I have to chose one of:
    • Suntooth Maul
    • Celestite Warblade
    • Celestite War-spear
    • Celestite Greatblade
    Additonally I have always the following weapon:
    • Fearsome Jaws and Stardrake Shield
    Is that correct? You can attack with multiple weapons "at once"?
    Iskander and Qupakoco like this.
  2. miturian
    miturian Member
    I think so?
  3. Trociu
    Chameleon Skink
    Trociu Active Member
    Instructions unclear, penis stuck in the Stegadon.
    But I think you are right.
  4. TwistedCoffin
    TwistedCoffin New Member
    You pick one wepon and then get a bite attack
  5. Ixt
    Ixt Well-Known Member
    Yep - when attacking, you attack with all melee weapons (in combat) and all missile weapons (when shooting) in the model's possession.
  6. pendrake
    pendrake Well-Known Member
    The old blood basically has claw-claw-bite.
    Always has the chomp with jaws, one limb has the shield on it, the remaining limb wields one of these four:
    weapons. Choose the one the model was assembled with. WYSIWY Choose.
  7. Kultak
    Kultak Member
    Yes, the Oldblood can have a maul, warblade, war-spear, or a greatblade. In addition he always has the jaws and shield attack. So depending on your configuration, the Oldblood will have 3 – 5 attacks.
  8. Korloq Huan
    Korloq Huan Member
    That is completely correct. Obviously with the weapon options he only has one of them per game. In the Attacking section of the rules, it states "pick the target units for the attacks that the model in the unit will make, then make all of the attacks". So since it says all it means all.
    AoS is a rules as written type of game so just treat everything as such. Just read the rules carefully and do exactly what it says on the tin and you shouldn't have any problems.
    Hope this helps
