    Dismiss Notice
KoW Fire elemental model
Discussion in 'Salamanders Discussion' started by Crowsfoot, Nov 20, 2016.
Tags:
  1. Crowsfoot
    Hey guys,
    What are you using for Greater elementals and the others?
    I'm looking to expand my Salamanders so give me options.
    SlanntaClause likes this.
  2. Rapax
    Rapax Member
    I made my Fire elementals from silicone paste. It is quite easy to shape into something that looks like flames.
    Here is the result:
    [​IMG]
    I am in the process of making a Greater fire elemental as well. Will post pictures when it is done.
  3. Crowsfoot
    Very nice and inexpensive I bet?
    have you a link to this paste?
  4. Itepixcauh
    Itepixcauh Well-Known Member
    As you might know I use my Slann as a GFE, and 3 Salamanders with handlers as a Horde of Fire Elementals, I have another Horde in Wipe too but I will finish my Tyrants first.
    Crowsfoot likes this.
  5. Crowsfoot
    I knew that :), but I was thinking of something like what @BAE has used but I have 2 salamanders I could easily repaint.
  6. Negator
    Negator Member
    A magmadroth. Ill post it up when im done painting. I also considered using the Aberration from mantic's warpath line.
  7. Rapax
    Rapax Member
    It cost me 30 SEK, which is around 3 euros, and was enough for two horde of Fire elementals. Quite cheap for 400 points worth of troops.
    I bought it from a hardware store here in Sweden called Biltema.
    http://www.biltema.se/sv/Bygg/Kemikalier/Silikon/Silikon-transparent-2000017158/
    Any hardware or similar store that carries chemicals and/or construction supplies would be my first bet.
  8. Crowsfoot
    That is cheap and a great idea.
  9. pendrake
    pendrake Well-Known Member
    Reaper makes a clear Orange-Red fire elemental. Item number 77082.
    Here are some pictures of mine:
    [​IMG]
    Top image is the ^ raw unfiltered ^ picture.
    There are filter gizmos in the camera and I started playing with them. Three of the results are below:
    [​IMG]
    [​IMG]
    [​IMG]
    Warden, Bowser and Crowsfoot like this.
  10. Crowsfoot
    They look good, what size are they compared to say a saurus warrior?
  11. pendrake
    That guy is ~2.5 times as tall as a Saurus Warrior. I will try to shoot a new pic with a size comparison for you.
    SlanntaClause and Crowsfoot like this.
  12. Crowsfoot
    Good lad ;)
  13. Rapax
    Rapax Member
    That's a nice model. I considered it for my Fire elementals, but the problem was I could only find one or two alternative ones (that I liked) and I didn't want a unit with several identical poses.
  14. BAE
    BAE Well-Known Member
    You can see a comparison to that model in the images of my whole army on the Salamander Paint Schemes thread. It fits a 50mm x 50mm base comfortably. Not sure whether it would fit a 40mm.
    Crowsfoot and SlanntaClause like this.
  15. Crowsfoot
    Do you use it as a Greater fire elemental?
  16. BAE
    Indeed, with Reaper Medium Fire Elementals as FEs.
  17. Crowsfoot
    Cheers bud, I like the look of them so on my christmas list they go.
  18. pendrake
    Comparison ^ picture...as promised.
  19. Crowsfoot
  20. mattjgilbert
    mattjgilbert New Member
    We are looking to see what we can do for elementals as part of the salamander army late next year.
