AoS converting to round bases
Discussion in 'Seraphon Discussion' started by kleptomaniac, Jul 24, 2015.
  1. kleptomaniac
    kleptomaniac New Member
    I've got plenty of Skinks and Saurus warriors so i'm going to put a few on round bases and build out those 2 "skink patrol" and "saurus host" warscrolls. My local gaming group has agreed we're going to measure base-to-base, not this "any part of the model" nonsense.
    I've put 10 skinks on round GW 25mm bases and they fit very nicely.
    I've got plenty of Privateer Press 30, 40, & 50mm bases. But before i go out and obtain more bases what base would you use for:
    Saurus warrior/temple guard
    Ripperdactal/Terradon riders
    Saurus Cavalry
    Saurus Old-Blood
    Saurus warrios fit just fine on a 30mm PP round base. I've glued 1 on just as a test.
    Ripperdactl/terradons feel like they should go on a 50 or 60. opinions?
    Cavalry fit on a 50. any disagreement.
    And finally, an old-blood. While it does fit on a 30 i wonder if it should go on a 40 to befit it's rank and station. Thoughts?
    Ritual likes this.
  2. Lord Sa'rk
    Lord Sa'rk Member
    About the cavalry, GW is gonna put new oval bases on pre-order tomorrow, so you might want to take a look at that.
    For the oldblood, yeh a 40 base would look nice, more space to add detail and bits :p
    Ritual likes this.
  3. Ixt
    Ixt Well-Known Member
    If/when I convert mine, I think that I'll carry all of the existing bases sizes over and match their diameters. Here's a chart from 2009 which matches a lot of base sizes to their models. We're on page 5.
    https://www.dropbox.com/s/82gbt5z20btzjdd/Warhammer base size chart.pdf
    I found a site with some nice, affordable bases recently: http://www.litko.net/categories/Bases-&-Base-Bottoms/Most-Common-Sizes/
    100 25mm x 3mm plywood bases for $12, to give you a rough idea.
    Never ordered from Litko before, though. Anybody have any experience with them?
    Ritual likes this.
  4. Scalenex
    Age of Sigmar uses the model not the base. Why go through the trouble of rebasing your old models? I don't see any tactical advantage to round bases. If you have keep the rectangular bases you can play Age of Sigmar and Oldhammer and Kings of War with the same models (they said an all scaly army is coming).
    Ritual, Canas and NIGHTBRINGER like this.
  5. NIGHTBRINGER
    I agree with Scalenex. Why go through all the trouble of rebasing?
    Ritual and Scalenex like this.
  6. William Jackson
    William Jackson Member
    there's no point in rebasing, it just costs more while only looking a tiny bit better.
    Ritual likes this.
  7. borkbork
    Ripperdactil
    borkbork Active Member
    Yeah, i ll side with Scalanex, Nightbr. and WJ. ....why bother.
    And with squares you also keep your options open for a game of 8th or Kings of War
  8. Lord Sa'rk
    Lord Sa'rk Member
    Although I myself am not going to rebase my models, I think it's a matter of preference. If the OP wants to do it then go ahead, and besides he wanted our help in choosing the bases that would better fit the models, not if he should do it or not :p
    Ritual likes this.
  9. pendrake
    pendrake Well-Known Member
    I do. Excellent firm.
    I have sent them CAD drawings before to make custom trays and bases. Working with Litko or a similar firm it ought to be possible to create round bases that square bases could drop into. Or ovals that would receive a big monster base.
    Like this:
    With a double layer base like above it would be possible to swap back and forth between rounds and squares.
    Ritual and Ixt like this.
  10. Ixt
    I've found that model-to-model measuring doesn't really work. In the long run, it may. With current models, however, it doesn't really hold up. That is the one rule that a lot of people are overturning.
    In my opinion, round bases are the way to go. They're best for Age of Sigmar. If you play WHFB, your round bases will probably be in a square movement tray regardless - arcs, then, can be taken from the movement tray. KoW, you'll probably just put a box of cereal or Ritz crackers on the board to symbolize the unit anyway... which doubles as a mid-game snack. ;)
    Ritual, Bowser and NIGHTBRINGER like this.
  11. pendrake
    One of the custom bases Litko made for me was a rectangle with round holes so I could use a mess of round-based D&D pre-paints to make a unit for Warhammer.
    Ritual, Bowser and Ixt like this.
  12. NIGHTBRINGER
    hahaha... nice!
  13. Ixt
    That is a great idea - quick and easy.
    Ritual likes this.
  14. little-myth
    little-myth Well-Known Member
    Well, the only models are getting round are my new Rippers, a little test. I don't seem to use Rippers much in Oldhammer. I will not be rebasing, fear of snapping poor Skink's legs off.
    Ritual and William Jackson like this.
  15. NIGHTBRINGER
    I agree that measuring from the model is absolutely absurd. It just lends itself to a whole slew of problems and abuse. The problem with measuring from the base in AoS is that there are no set base sizes. If one is to attempt to maintain even the smallest figment of balance in AoS, an established set of rules for base sizes must be created and agreed upon.
    Ritual likes this.
  16. Ixt
    I thought that not even 8th has a rule for base sizes, though.
    Ritual likes this.
  17. NIGHTBRINGER
    The rule was play the model on the base that it was supplied with (or the most recent iteration of it). There were a few problems here or there, but for the most part the bases were extremely well established.
    Ritual likes this.
  18. Ixt
    Never saw that rule or suggestion or anything. Having a hard time finding it now. If it's unspoken, can't it stay that way?
    Ritual likes this.
  19. Caprasauridae
    Stegadon
    Caprasauridae Well-Known Member
    Rebasing doesn't prevent you from playing Kings of War. There are companies that make trays that can fit models with round bases, and I would think more will emerge. I have based my Daemons on round bases for 40k, and will get some laser-cut MDF trays for Fantasy.
    And what comes to the original topic, the Plastic Krak blog had a conversion table made, which might be helpful:
    http://plastickrak.blogspot.fi/2015/07/age-of-sigmar-base-conversion-chart.html?m=1
    Ritual likes this.
  20. Ixt
    Interesting... why change the sizes themselves, though? Why not use the current diameters?
