So quick question: if you declare a charge and the enemy unit flees, what is your charge distance if you elect to complete the charge? Is it 2D6 or 2D6 + M? I am somewhat confused by this summary sheet.
Seems legit... Edit: " if you declare a charge" oops I missed this part, yea add your movement here. the rule the sheet is referring to, is when one side flees while already in combat.
Page 19 of the brb says when calculating charge distance use movement plus 2D6. Looking at the summary sheet, it doesn't seem like someone from GW made it so I am guessing that it is either a typo or they confused it with the pursuing after combat distance.
