Beginner needs help
Discussion in 'Introductions' started by Lagan, Feb 14, 2018.
  1. Lagan
    Lagan New Member
    Hello, I'm new to Age of sigmar, I've been playing with friends for about a month, and I've loved the Seraphon!
    I have decided to make my first purchase and I am not sure which box to buy, first I show them what I have:
    1 Slann Starmaster
    1 Eternity warden
    15 Temple Guard
    2 Skink Priest
    3 Kroxigor
    15 Skink
    1 Saurus OldBlood
    I thought of the start collecting Seraphon, but I was also interested in buying two boxes of saurus warriors, what do you think? Is it convenient for me to buy one of these or do I want to buy another? I do not know which would be better because I do not know much about the game, so I looked for advice or help in that sense.
    What box do you recommend to buy?
    Thank you very much!
  2. Aginor
    Welcome!
    If you like Saurus I think I would still recommend getting a Start Collecting box because you can make SO many things out of that one for a lot of different lists, including an Astrolith Bearer for example, which is a very useful Saurus hero.
    Our friend @Crowsfoot made this thread about it:
    http://lustria-online.com/threads/getting-the-most-from-your-start-collecting-seraphon-box.20560/
    But after that, yeah, if you want to go Saurus heavy then you will need 2-3 boxes of Saurus Warriors. The minimum to properly play Saurus are 40 Saurus, and if you want to try out the Sunclaw Starhost bataillon which makes them pretty good you will need a minimum of 40+10+10, so 60 Saurus, and a Sunblood to support them.
    Warden, HeirofCarnage, n810 and 2 others like this.
  3. Lagan
    Lagan New Member
    Thanks for your answer! I have a doubt
    Should you play with saurus? or what strategy is better?
    I have seen that many take formations more to bastilodones with many skinks, or that use Engine of the gods.
    Or which is the one that is better now?
  4. Aginor
    Well, I'll be honest: I like big beasts and I cannot lie big beasts are usually ridden by Skinks, so....Skinks rule. :D
    Saurus, especially with the Sunclaw bataillon are not bad though (in fact there was a mass Saurus list in the top5 of a recent tournament IIRC) , you just need a lot of them since they suck in small units.
    If you build a solid lists using proper synergies they can be effective. It depends on your play stlye (and on your opponents) as well.
    Warden, Lagan and Crowsfoot like this.
  5. HeirofCarnage
    HeirofCarnage Well-Known Member
    First off, Welcome!!!!:);)
    Secondly if assembled properly, the "Seraphon" (@NIGHTBRINGER goes into a fit of autistic rage) starter kit will get you
    1 Astrolith bearer
    1 Carno with Old blood/Scar-vet on it
    1 troglodon
    1 skink priest
    1 one Sun blood (or old blood) on foot
    3 Scar-vets on Cold ones
    10 Saurus warriors
    5 Saurus knights
    I can go into detail on how to make each, but I won't unless you want me to. The Starter kit it sooooo good! If assembled in the way I specified, it gives you
    At least $95 more of value then the normal starter kit. (7 extra heros at 15 bucks apiece would be $95) and an extra behemoth!
    Here to help,
    ~Carnage
    Captaniser, Warden and Lagan like this.
  6. HeirofCarnage
    Do you want a simple answer as to which strategy is better?
    The answer, NONE!!!
    The rule books are always changing. What might be "better" now might suck tomorrow!
    So choose miniatures that you like, and work from there.
    Captaniser, Scalenex and Lagan like this.
  7. pendrake
    pendrake Well-Known Member
    I think the best choice is the Start Collecting Box as well.
    You would have, this:
    1 Slann Starmaster
    1 Eternity warden
    15 Temple Guard
    2 Skink Priest
    3 Kroxigor
    15 Skink
    1 Saurus OldBlood
    ......plus, all this:
    1 Astrolith bearer
    1 troglodon
    1 skink priest
    10 Saurus warriors
    5 Saurus knights
    ...by the time you finish assembling. A very nice variety of models to pick from.
    Captaniser, Warden, Lagan and 2 others like this.
  8. HeirofCarnage
    I think you might be wrong. I searched all over amazon and the official shop, and there is no set with those sprues. There is no Slann model, and no Kroxigor models on the sprue. If you custom made them like I am doing... but that wouldn't be part of the kit.
    Captaniser likes this.
  9. Aginor
    I think @pendrake already factored in what @Lagan wrote in the OP.
    Captaniser, pendrake, Warden and 2 others like this.
  10. n810
    n810 First Spawning
    "There is no Slann model, and no Kroxigor models on the sprue."
    That's because they are not plastic. o_O
    (they are either metal or resin depending on what casting you get)
  11. pendrake
    Exactly.
    The models I listed were what he already had + the start collecting box.
    You got it in one @Aginor.
    Lagan, HeirofCarnage and Aginor like this.
  12. Scalenex
    Somewhat belated welcome to the forums!
    I normally say let us know if you have any questions but at looks like we already have some healthy questioning and answering here.
