Blog Army Of Xlanzec
Discussion in 'Personal Paint Logs' started by ASSASSIN_NR_1, Oct 17, 2014.
Tags:
  1. ASSASSIN_NR_1
    Just to have a fancy name for my army :D
    My saurus:
    It is quite some time ago, that i painted these. they are rather dark.
    they have become more and more red, as I have come to like the blue with red scales.
    Skinks:
    I plan to get some more, and paint them, to proxy chameleons.
    My first Stegadon:
    and again it is very dark, as it is one of my early models.
    My second Stegadon:
    I do like this one over my other stegadon. it is more bright and overall I think I did a better job painting it.
    Moving to more saurus, or rather temple guard.
    these are a bit wierd, in the sense that they do not fit with the rest of my army.
    my old salamander, which might need a repainting.
    Now to the first unit I ever got:
    I did not have a wide range of colors when I painted these, so the saurus only have one single blue color.
    My second unit of cold one riders. as with the temple guard, they are a bit off. I actually have some more cold one riders, I have begun painting. A bit of a waste sadly, as I rarely use them.
    On to Characters:
    Skink Priset:
    he is my only mage. I probably should get some more.
    My Saurus on Carnosaur. I have never really used him because I am mostly playing against cannons or games that are just too small for him to fit in the 25% of Lords or Heroes. and now, he is outdated.
    Chracter on cold one:
    I do like him, but again, he does not fit the rest of my army.
    Scar vet:
    he was made to be Gor-Rok. As he did not have a model in the last edition, now he is most often used as a scar veteran.
    Oldblood:
    Just a standard oldblood, not much to say. He fits the theme of some of my saurus though.
    And now, My favorite model:
    Gor-Rok
    I tried to have his shield look like it was made out of blue obsidian. But its not that clear on the picture.
    I use him often, as I love his backstory, and he is a real beast on the battlefield, He and an oldblood have practically slaughtered a unit of 50 empire soldiers, and had two other units in their flanks flee. the one getting run down by my stegadon. and Gor-Rok and my Oldblood, did not loose a single wound, even though there were two characters in one of the empire units.
    At the moment I am painting an Oldblood, which, hopefully, will be finished soon.
    Warden and Scalenex like this.
  2. n810
    n810 First Spawning
    Looking good man, an impressive amount of work. :smug:
  3. Vosrik
    Vosrik Well-Known Member
    I especially like the blue you did on Gor-Rok's shield, how do you paint your blue obsidian?
  4. ASSASSIN_NR_1
    Hi vosrik
    the way i made Gor-Roks shield, was by painting it balck, and painting with Caledor sky on all edges. aftewards I painted the edges with Teclis blue, and painted some stripes (I guess they could be called that anyway)(maybe a bit hard to see on the picture). and to finish it I painted with Ardcoat.
  5. rychek
    rychek Active Member
    He may not be the most current sculpture, but he is definitely still usable. He is just as effective (if not more effective) as the new model too!
  6. ASSASSIN_NR_1
    If you say so, I will probably try using him, as I love the Carnosaur, and it is sad if he is just standing around being useless.
    And it might be a good indicator whether or not I should get the new carnosaur model at some point.
  7. ASSASSIN_NR_1
    Now with the new rules that came with the end times it will be easier to field carnosaurs.
    (My oldblood i soon finished, so I will post a picture soon)
  8. DanBot
    Ripperdactil
    DanBot Member
    I'd change his base, But I don't think you need the new model at all. In fact I prefer the old model at this point. I do wish it was a bit larger, But it looks much better IMO. esp the dinosaur's head.
  9. ASSASSIN_NR_1
    Do you have any solution on how to change the base/get him off of it? He is glued to the base with super glue, and I do not know how to do it.
  10. ASSASSIN_NR_1
    My new oldblood:
    sadly the pictures are a bit blurry, so some details are lost.
    His armor is generally black with purple patterns on, to try an get an obsidian effect. the same I did with the weapon and the snake on top of his head, just with red instead.
    Warden likes this.
  11. ASSASSIN_NR_1
    I have just taken apart my Carnosaur, because the saurus´ head fell off, and I thought: Screw it.
    I want to repaint him(as he had also lost some paint), and while i am at it, give him the right sized base.
    I want to ask, if anyone have a solution to strip him of paint.
    And if anyone has an idea for a cool colerscheme (carnosaur only).
  12. Fhanados
    Fhanados Well-Known Member
    Depends on what he's made of. For metal models I use mineral turpentine or methylated spirits - but by the Old Ones do not use this on plastic!
    Some people use a cleaning product called Simple Green on plastics and resin, but I've never had any success with it. I prefer Dettol antiseptic. Not the wash - just straight up medical antiseptic. Leave your mini in a tub of it for a day or two then attack it with a toothbrush. Be warned, it is very messy and can leave the plastic a bit brittle (but not too bad).
    I've never stripped resin or finecast so I'm not sure about them sorry.
    I also hear brake fluid works, but I haven't been game to try it.
  13. ASSASSIN_NR_1
    Thanks a lot!
    I will try it out
    (he is the old metal model)
  14. ASSASSIN_NR_1
    I think I found a cool color scheme:
    It is probably above my level of skill to paint that, but I plan to try anyway.
    Warden, kubapj and Scalenex like this.
  15. Fhanados
    Agreed, that IS a cool colour scheme!
    I've got the old Kroq-Gar carnie in finecast (same as the old metal one I think). Maybe I'll give this a shot too!
  16. ASSASSIN_NR_1
    I might actually make my carnosaur different from the pictures and then again similar. maybe similar but different.
  17. ASSASSIN_NR_1
    I made some qiuck pictures of color schemes for cold ones. I cannot quite figure out which one to go with for my own. Maybe someone could give their opinions. or come up with even better color schemes.
  18. ASSASSIN_NR_1
    I took some new pictures in a better quality of some of the models I thought did not get a proper picture the first time around:
    First up is Gorok:
    And a clearer picture of the shield:
    Now the blue lines going across the shiled are visible.
    An oldblood (tried to do the same with his armour as with Gorok´s shield, with difference in color):
    Warden likes this.
  19. ASSASSIN_NR_1
    I also repainted some of my older models, as they are metal and some of the paint had fallen off. They have also become the first models I have based properly.
    Skink Priest:
    He now fits more with my overall army scheme, and have become a lot lighter compared to what he was before.
    Skinks for my Slamander (one of them):
    He too fits better with my overall army scheme.
    Newly painted models:
    My skink Chameleon skinks:
    These are my first Chameleons. I often play against Empire, so a counter to Empire´s "Gatling gun" is very nice indeed.
    Warden likes this.
  20. ASSASSIN_NR_1
    Now some of the models I am currently working on:
    The salamander
    The colors are inspired from a model of Smaug.
    Cold one
    Rider
    I have grown kind of fond for the obsidian look (well that is at least what it is supposed to look like).
    These two are practically done, but I still have 7 more to go.
    My old Saurus and Carnosaur, which I am repainting:
    I have also just begun working on a Bastiladon. Maybe I have too many balls in the air at the same time :D
    Warden likes this.
