AoS Second Edition
Discussion in 'General Hobby/Tabletop Chat' started by Lord Agragax of Lunaxoatl, May 12, 2018.
  1. Tokek
    Chameleon Skink
    Tokek Well-Known Member
    Well yes. If you can't snipe the lord ordinator and you can't snipe the enemy wizard and you can't kill or engage the engines themselves...
    Then you have failed to have a counter to pretty much any part of their army and you are going to have an uphill struggle that game.
    I thought the ballista would be in the 120-140 points range, I am a little surprised if they turn out to be 100 but not totally shocked and the sky is not falling. They will be a common sight at 100 points and it will be worth thinking about how to counter them when building a list. If after all of that works its way through the cycle of build/test/play and they turn out too strong I suspect they will get some nerf sooner or later.
    Crowsfoot likes this.
  2. Crowsfoot
    SCE so it will be a buff
    NIGHTBRINGER likes this.
  3. Aginor
    Ok another source says 120 which is still on the cheap side IMO but a bit less crazy.
    About countering them: as long as they cannot be taken in a bataillon at least there is a good chance they won't go first.
    If they do go first there is not much you can do to counter them as you won't be able to act before they do.
    The palisade might work after that if it isn't unbound or dispelled before doing anything.
    Either way, it could be worse. I guess. It could be doing mortal wounds and/or ignore line of sight...
  4. Crowsfoot
    Don't give GW ideas .......
  5. Canas
    Canas Ninth Spawning
    Maybe it's an indication we'l just see rather massive point drops across the board or that summoning is going to bring in an metric ton of reinfocements? That or they're expecting them to be horrificly unreliable with the hits they generate? In any other situations an artillery piece that essentially has D6/3+/3+/-2/1 or 4D6/5+/3+/-2/1 at close range is going to be faaaaaaaaaar too cheap for a 100. Even without external buffs there's going to be little that can stand being fired upon by that...
  6. Wazz
    Wazz Well-Known Member
    Core rules are up. Can't figure out how to get the link posted lol sorry.
  7. Canas
    select some text in your post then click on the lil button that looks like a chain at the top of the editor, paste the url into the popup click ok, text should be purple now.
    Wazz likes this.
  8. Burwinkelito
    Burwinkelito Active Member
  9. Burwinkelito
    I think he means he doesnt know how to do it because his message appears to be awaiting for a moderator. As mine does
    Captaniser and Wazz like this.
  10. Wazz
  11. Lord-Marcus
    Lord-Marcus Sixth Spawning
    Welcome!
    Wazz likes this.
  12. Burwinkelito
    Thank you!
  13. Nefertem
    Nefertem Well-Known Member
    Sorry my bad, was to upset...seems one cd
  14. Padre
    Stegadon
    Padre Well-Known Member
    So, after my first read through of the new rules, it looks like the Rules of 1 are now in the core rules. And there is a rule rule that states that warscroll abilities take precedence. So, if I'm reading it right, Kroak can cast his spell up to three times and Ripperdactyls get their hit until they miss rule back.
  15. Aginor
    I fear you might be wrong.
    The paragraph is about abilities, not spells, so Kroak would not profit from it.
    Also there is a paragraph on page 14 (left side) that says that attacks cannot generate more attacks.
    Edit:
    Uhhh wait I think you might be right with the Rippers actually if the warscrolls take precedent and the warscroll is not changed.
    Ecozh likes this.
  16. Padre
    Stegadon
    You are probably right on Kroak, although I think you can argue that it may be intended that he can. That may need to be an FAQed.
  17. Aginor
    Ok here is good news and bad news.
    Bell of lost souls has a video.
    I paused it on the summoning page for Seraphon and took a screenshot that I can read.
    We will probably not get new warscrolls. They just basically wrote "ignore all the summoning spells".
    There is a paragraph for the Engine of the Gods however!
    It says: when rolling 14-17 pick one of the units in the list below and set them up wholly within 12" of the EotG and more than 9" away from the enemy:
    - 20 Skinks
    - 10 Saurus Warriors
    - 3 Ripperdactyls
    - 3 Terradons
    Wazz and Chico like this.
  18. pendrake
    pendrake Well-Known Member
  19. Chico
    Chico New Member
    That is great! I mean, it doesn't really add to our new summoning mechanic by adding point or anything, and it IS a limited list, BUT at least it's waaaay better than 14-17 doing nothing, as has been the case so far.
    Additionally, I noticed this in the rules:
    SPLIT UNITS
    At the end of each turn, you must remove models from any of the units in your army that are split up into two or more groups, until only one group of models from the unit remains in play. The models you remove count as having been slain.
    I don't know if I've just missed it or somehing, but this is new right? No more splitting up a conga-line from the middle, to have one unit covering two objectives.
  20. Crowsfoot
    It's actually around 9 pages the rest is battleplans etc
